Old 12-16-2011, 09:06 PM   #11
Rory McNeil
Default Re: NHRA allows Alum heads in stock/ss
I`m not sure if all the Edelbrock heads have no exhaust crossover passage or not, but I know many do. Yet with a factory head, you are not allowed to plug the crossover into the bowl area. Also, I`m pretty sure that not all the new heads approved use the same combustion chamber volume or valve sizes for every application that they are approved for. Interesting, eh?
NHRA 6390 STK
M/S 85 Mustang
Old 12-16-2011, 09:43 PM   #12
Tim Ellis
Liked 7 Times in 6 Posts
Smile Re: NHRA allows Alum heads in stock/ss
I wish the Performer rpm heads were ok'd for stock too, especially for my 89 5.0l
Tim Ellis is offline   Reply With Quote
Old 12-16-2011, 11:06 PM   #13
Bill Harris
Liked 26 Times in 13 Posts
Like the Olds head, the Edelbrock is only specified for SS for the 429 CJ Ford motor (at a 10 HP premium), of which there has been exactly one built in the last 20 years, and it hasn't been run in two years. The stocker still has to run the OEM unobtainium version. And there are those who are bitching about the lack of Chevy heads... don't make me laugh...
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 12-17-2011, 12:06 AM   #14
Sam Murray
Sam Murray's Avatar
Liked 60 Times in 29 Posts
Originally Posted by Wade_Owens View Post
So, port shape, location, valve size, chamber size and shape, guide diameter, shape and height, etc, are all EXACTLY the same as stock? Outside of aluminum saving some nose weight, why did Edelbrock go to all the trouble?
WTF!!!!!!!!!!!
Where did this B_ _ L S_ _ T come from????????? First roller rockers and now this! I'm beginning to think the manufacturers are winding up NHRA, the whiners and the cry babies! Just what we need in this economy more unneeded expense.
I'm sure Farmer is rolling over in his grave?
Sam Murray
1616 STK
Sam Murray is offline   Reply With Quote
Old 12-17-2011, 12:15 AM   #15
Tim Ellis
How is it an unneeded expense? You don't have to run them, AND in my case in Superstock (if I ran superstock, not stock)it would be Cheaper to buy a set rather than have a set built. I just checked all years of smallblock Ford included (64-81) and can't find a single year or model the Edelbrocks are allowed in Stock, SS only. Others have Stock availability, such as 352, 390, 428, from what I can see.
Old 12-17-2011, 02:18 AM   #16
Hudlow66
Hudlow66's Avatar
Originally Posted by Chris DeGidio View Post
The Edelbrock 383-440 Mopar heads are the same as the Mopar "452"aluminum heads Mopar sells thru MP.They are made for Mopar by Edelbrock,and are legal for S/S.The 2012 Flyer has a part number and says they are legal heads.The Edelbrock heads typically are cheaper price wise than the Mopar 452 aluminum heads.
The Eddy and 452 Mopar heads have 2.14 I and 1.81 E valves whereas the OEM iron head are 2.08 I and 1.74 E.
Neither one of these heads would work for somebody running a '66 383 combo, would they? 2.08 in. but the little 1.60 ex. (like the early "915")
Phil Hudlow 6678 (S/C, S/G, ET-PRO)
Hudlow66 is offline   Reply With Quote
Old 12-17-2011, 02:54 AM   #17
Dean3870
JOKE!!! just call it jr. comp
mike dean
3870
Dean3870 is offline   Reply With Quote
Old 12-17-2011, 03:26 AM   #18
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: NHRA allows Alum heads in stock/ss
Edelbrock #
60107 - 67-73 AMC 343-401
60037 - 67-69 Buick 400-455
61767 - 92-30 Dodge 318-360.......< This is a misprint! I think they mean 92-03 Magnum engines and not the earlier LA engines?
60217 - 64-81 Ford 289-351
60697 - 69-78 Ford 429-460
61657 - 70-71 Ford 429CJ
Old 12-17-2011, 08:07 AM   #19
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
If the Mopar 452 head is listed in the engine guide for the 1966 383 S/S combo,then it is legal.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 12-17-2011, 01:44 PM   #20
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: NHRA allows Alum heads in stock/ss
Just think of the good part.....When NHRA/IHRA trashes stock you will be all set to run the 10.90 class or maybe 9.90's if you junk is quick enough.
