Old 12-08-2011, 01:33 PM   #1
jaf2021
Liked 5 Times in 5 Posts
Smile wagon fuel cell
any ideas on putting a fuel cell in my 66 chevy 2 wagon whrere it would be legal?
jaf2021 is offline   Reply With Quote
Old 12-08-2011, 02:48 PM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: wagon fuel cell
The 6-passenger full-size wagon's have a luggage compartment in the very rear of the load floor, where the "rear-rear" seat would fold on the 9-passenger. If the Chevy ll has the same set-up, that's where I'd put it. You won't need to fabricate a fire-proof bulkhead, because the compartment has a hinged steel cover. Cut a hole in the floor for the sump, and get the mounting kit for the size tank you purchase.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 12-08-2011, 04:43 PM   #3
GTX JOHN
That is exactly where my kid's is at. However, I have seen them mounted
in plain sight in several wagons as far back as possible and simply vented
to outside(Seen at Nat'ls)........I guess that must be OK too?
I am Happier myself with it behind Bulkhead on boy's wagon.
Old 12-08-2011, 05:57 PM   #4
jaf2021
Lew my floor is straight from the back seat to the tailgate. if i was to put it on the top and cut a hole for the sump wpuldn't i have to make some kind of box around it to be legal?
Old 12-08-2011, 06:44 PM   #5
Lew Silverman
I'm far from an expert, but I do know that the tank has to be shielded from the drivers compartment by a fire-proof cover/enclosure and vented outside the vehicle body. Coupes and sedans have back seat bulkheads that when properly modified satisfy the rules. Maybe you can build a box to put the tank in and mount it below floor level with a hinged steel or aluminum cover.
I wish I had better advice for you, but I'm sure someone on Class Racer has already done what you're attempting.
One other thought - I think CompetitionPlus did a few articles on their "cloning" of Gene Fulton's old Nova wagon. Might be some good info there.
Good Luck!
Lew
Lew Silverman #2070
Old 12-08-2011, 07:04 PM   #6
Jack McCarthy
Liked 477 Times in 117 Posts
Exclamation Re: wagon fuel cell
lew > i had a guy (tommy mattingly) make a cell that fits in the quarter just under the fuel door. it looks like a shoe box, bolts to the frame, holds about 5 gallons and uses the original fuel inlet from the car... it is the **** do not have to roll window down open tailgate etc... just like factory.
travis approved mine !
jack mccarthy
call ill try to make a pic or too
502-558-3450
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
