I would suggest it appears you lost a lot of HP between the dyno and the track. ;(
Jeff Lee 7494 D/S '70 AMX |
Liked 6 Times in 2 Posts
Exactly my thoughts. How much weight are you hauling?
Dale Posnick |
Liked 2 Times in 2 Posts
The car weighs 3500 pounds and RWR power .All steel.
Cam Cam our best 60' is 1.42 10.9 @ 120. 3150# with a little weight in the rear bumper. 5.86 [ was about the same with 5.57 ] 3.2 1st in transmission .84 Trans Am body probably worth a little MPH. We also have AVO shocks about the same settings. MT 29.5 9 slicks 12 lbs. warm . Lighter springs in the pp really helped---Trevor
If the dyno is correct, 690 HP would be around 135 MPH. That's 5-6 more than you are showing. Fixing the clutch or traction issues isn't going to bring the MPH up much, if any. So the bottom line is, something is amiss in the HP department of the vehicle. That could is typically ignition or fuel issues. As an example, you will feed plenty of fuel to the engine while it is on the dyno because there's nothing to cause problems. But if the fuel system is not able to keep up with the engine while under a heavier load, or the system can't push enough fuel through the system, then your HP will be cut drastically. And in your case, I see 75+ missing. That's significant.
My suggestion is to find the missing HP which will cure the low MPH issue. Then you can work on the rest of the car.
#6 | |
Well i don't think rick waters lied about the figures, we know there is a gremlin in the chassis. But do appreciate the advice. We will keep searching.
If you re-read my post, I didn't say the dyno HP is a lie. I'm saying the HP got lost on the way to the track. Don't take it personal, it happens a lot. Fuel, ignition, gearing, hood clearance, etc., there are many ways to loose power.
Liked 306 Times in 103 Posts
How much tq.@ what rpm does tq.&hp peak@.
I don't know anything about your combo, but I would guess launch is too low,clutch probaly too tight, 4.88 gear too high. it's choked down. Mike Taylor 3601 |
What's the transmission gearing? Where are you shifting it and what's the rpm at the finish line??? I'm having a problem seeing how a 3,500 lbs car with a small block making 690 needs a 4.88 gear.
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
