Old 05-14-2007, 11:05 PM   #1
Bill Marshall
Liked 53 Times in 24 Posts
Default GOOD LIGHT WEIGHT BATTERY
I AM LOOKING FOR A GOOD LIGHT WEIGHT BATTERY THAT HAS ENOUGH RESERVE TO GO A FEW ROUNDS OR RECHARGES FAST BETWEEN ROUNDS
Bill Marshall is offline   Reply With Quote
Old 05-15-2007, 12:07 AM   #2
Kip Martin
Default
Rock battery
Kip Martin is offline   Reply With Quote
Old 05-15-2007, 12:10 AM   #3
Bruce Fulper
Liked 54 Times in 33 Posts
Default
Kip? Where d'ya get a "Rock" ?
I miss step.
Bruce Fulper is offline   Reply With Quote
Old 05-15-2007, 01:05 AM   #4
Kip Martin
Default
I got mine from Les Figueroa at the track. It works great.
Old 05-15-2007, 01:47 AM   #5
Bruce Fulper
Default
12 or 16 volt ?
I miss step.
Old 05-15-2007, 02:10 AM   #6
Jeff Lee
Guest
Posts: n/a
Default
Here's my cheap lite-weight solution. They make a special size (I forgot the group number) for Honda Civics. Tell them you have a 1992 Civic. No more than $58.00 depending if you get the standard or premium model. Buy two. Charge both the night before. Use one for qualifying then change it out for eliminations. You can charge the 1st battery and if you make it to the 4th round, rotate the battery. Besides being cheap, they weigh only 15 pounds each. I never had one problem in Stock with my 390 engine and constantly forgetting to turn the water pump or fan off while in the pits.
NHRA #7494 SS/H
1970 AMC AMX
"Best Appearing" @ NHRA '06 Pacific Sports Nationals
JeffLeeAzRealty@Qwest.net
602-418-9797
Old 05-15-2007, 04:23 AM   #7
76 RACER
Default
There is a battery company in the Phoenix area that has every type of battery produced. I looked at the ones used in NASCAR. Very light and must work well.
76 RACER is offline   Reply With Quote
Old 05-15-2007, 10:23 AM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Default
I did the same as Jeff Lee. Went t o Walmart and found a small battery with 650 CCA weighs about 28 lbs. costs about $50.00. Saved about 30 lbs over th group 27 battery.With a full charge and a retard control on the MSD I have no problem starting my 350/ 295 super stock camaro even when going round robin in eliminations
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-15-2007, 11:35 AM   #9
Chris 2421
Default
Odyssey has a small battery that is about the size of maybe a cross between a lawn tractor battery and a motorcycle battery,plenty of reserve and CCA.Summit has them for about $130.
Nautilus Racing
Nautilus Racing
Chris 2421 is offline   Reply With Quote
Old 05-15-2007, 05:17 PM   #10
AntroRacing
Liked 29 Times in 6 Posts
Default
The Odessey batteries are a really good battery to go with. They are a completly dry battery and they have tons of power. They weigh a bit less than the Optima battery but have more power.
AntroRacing is offline   Reply With Quote
