It's time for new wheels on my Mustang. I would like a retro look, but not sure I can go as far back as Cragar S/S - I like the American Racing Torq Trust Pro - but Geeeeeze are they expensive!
![]() Also - do bead locks present a rear caliper clearance problem? - I use a Lincon rear brake setup on this car. ![]() Thoughts? |
Liked 99 Times in 60 Posts
check the web sites of Hole Shot Wheels and Bogart Racing Wheels. You might find just the wheel.
Larry Woodfin 471W |
#3 | |
Liked 5 Times in 5 Posts
Don't be afraid to "go as far back",,its a timeless look! Good luck whichever way you go. Danny Durham |
Liked 6 Times in 4 Posts
Aren't the Cragar SS wheels relatively heavy?
Liked 535 Times in 110 Posts
Yes they are, although it's been 25 years since I've even lifted a set.
Jim Kaekel 3836 STK |
Liked 2 Times in 2 Posts
Not trying to hijack your thread but with you guys talking about weight. What are the lightest wheels out there?
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
I've seen wheels that were awfully light, they were actually CNC-profiled on the back side, but also wound up breaking on a friend's car when he turned onto the return road. If you've got a car with a light front end, a real light wheel would probably be OK. I've looked, there are quite a few relatively light wheels out there including Weld Aluma-Star & Magnum, Billet Specialties Comp Series, Bogart, Holeshot, Sander (builder of American Racing drag wheels), etc.
Yeah, light wheels - that's why I'm shopping for wheels. I bought Bogarts as seen in the avatar at left. The screw holes are stripped out from trying to screw into tire beads after a fresh pair of slicks and the tire mounting guys have bent them twice now. So I need something less problematic ...I want to drive my car, not set ET records. So considering a steel rimmed half breed like the Cragar SS has some alure. So do beadlocks, but my rear calipers are probably too large to clear??? I did look at Holeshots website - the Sun Flare looks cool like an old set of Rayder wheels...any more input?
Check out the MT wheels too.
They were actually lighter than the Monocoques, but they are stronger and have a nice wide bead. We cracked both front Monocoques on a light 66 Nova that won't turn. Not a good deal.
James Schaechter 3163 STK |
the M/T wheel is high on my list. too bad they dont offer the beadlock in 15" as all their 16" tires are 16" wide too
