Old 09-18-2011, 06:17 PM   #21
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Default Re: CJ mustang engines
Originally Posted by Charley Downing View Post
Poor poor Andrew and his -1.20 D/SA and E/SA car.
I think I may have JOEL Build me a C-4 for next year. I like the idea of my 281ci car kicking the ***** of old 350's in D/SA, E/SA and F/SA.
Go for it! You might have to take that throttle stop off and go fast enough to get around 90 HP though.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 09-18-2011, 07:56 PM   #22
Charley Downing
Liked 653 Times in 89 Posts
I will be in columbus with the same parts I had at INDY. We will see if I get to race?
Andrew I am game for anything. If I were to get 50 hp I could run E/SA at #2970. I don't see all the crying over a little 281.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 09-21-2011, 08:38 AM   #23
james schaechter
Good Luck Charley. Hope to see that killer under full power!
I would probably get my rear kicked even racing you in E, but I sure would like a shot at it.
Better than trying to race you in J anyway. You have the power to get to E all by yourself.
Just run her out a few hundered feet more. LOL.
James Schaechter 3163 STK
Old 09-21-2011, 08:42 AM   #24
Charley Downing
James just put the 283 back in her and we can race all the time. I will even give you a small head start. Even if I beat you I can't pass tech.
Old 09-21-2011, 08:49 AM   #25
james schaechter
Define Small. LOL.
I thought Ford fixed their clerical error on the parts anyway. Not done yet ?
Old 09-21-2011, 09:00 AM   #26
Charley Downing
No the clerical error is fixed.
Just for you James I will run it balls out to 800ft this weekend.
Old 09-21-2011, 09:31 AM   #27
james schaechter
Don't get too wild, people will think you got a bromance going for us 283 racers.
Old 09-21-2011, 10:54 AM   #28
Dave Casey
Liked 804 Times in 168 Posts
Well, since this thread is about CJ engines, I do have a question
do the 428, 352, and 281 engines that are being run in stock use a conventional style intake manifold with a throttle body on top like the Drag Paks use ?
Dave Casey 1330 STK
Old 09-21-2011, 11:11 AM   #29
rawhide
Liked 7 Times in 5 Posts
Dave,
The 352 and 428 use an intake and throttle body similar to the Drag Pak. The 281 uses the standard type fuel injection system.
regards, Roland
rawhide is offline   Reply With Quote
Old 09-21-2011, 11:15 AM   #30
Bill Harris
Liked 26 Times in 13 Posts
The352 and 428 engines are old windsor SBF based pushrod motors which do use a conventional intake with a four barrel throttle body. The 281 is a mod-motor, overhead cam engine, but I think it uses the OEM style intake (composite/plastic?) with a newer style single hole TB.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
