Old 09-17-2011, 12:20 PM   #1
Liked 1,815 Times in 413 Posts
Default Re: NHRA Announces Changes to Class Guide
Originally Posted by C and W Racing View Post
Was told in tech that next year there will be a 6, 6 1/2, and 7 lb weight break, so Fezell will be back in stock.
Chuck
A 7.0 class makes sense, but having 6.0 and 6.5 weight breaks is just stupid. Those are Super Stock weight breaks, for a reason.
Old 09-17-2011, 12:52 PM   #2
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
[QUOTE=Alan Roehrich;283219]A 7.0 class makes sense, but having 6.0 and 6.5 weight breaks is just stupid. Those are Super Stock weight breaks, for a reason.[/QUOT
a lil reliable birdy told me they would be in there own class next year...
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 09-19-2011, 10:10 AM   #3
Bobby DiDomenico
Liked 101 Times in 52 Posts
Question Re: NHRA Announces Changes to Class Guide
Originally Posted by Mike Carr View Post
Indy, AA/S, 7.5 pound class, 476 hp rating (at that time), 3,740 minimum weight, 9.38 et @ 148 mph
Charlotte, SS/E, 8 pound class, 425 rating, 3,570 min wt, 9.20 @ 150
Mike,
If we read this correctly they expect a car with more modifications and 170 lbs less wt to run just .18 quicker?
Old 09-19-2011, 10:16 AM   #4
Chad Rhodes
Originally Posted by Bobby DiDomenico View Post
Mike,
Well it did it with no modifications from how he ran it in stock.
Chad Rhodes 2113 I/SA
Old 09-19-2011, 10:40 AM   #5
Bobby DiDomenico
Chad, seems I hit the go button and wiped out a line without trying. Was going to ask if it weighed the same or the 170 lbs. less. Have some non racing engineering friends interested in this because of the vast differences in HP and WT being described. To clarify you can only add enough wt to move up or down a class (as in you cannot be too heavy and run slower than you would at max class weight using the class numbers) but in AA/SA many of these cars have over 500 lbs of weight added? They want to know if there is a rule on where the weight is added. Must it be split to 50/50, etc.? I thought NHRA removed the nose heavy % requirement many years ago.
Thanks
Old 09-19-2011, 02:17 PM   #6
Tom P
Liked 239 Times in 94 Posts
6.0lb Stockers ... like a 427 Cobra? Unfortunately that wouldn't run with the CJ's and Drag Paks either but it'll be interesting to see how deep in the 8's a Stocker will go.
