Old 09-15-2011, 11:20 PM   #1
Phillip marvetz
Phillip marvetz's Avatar
Cool Re: M2000 helmets R I P
Originally Posted by Jim Wahl View Post
Hey guys it's your head! What's it worth? You should only buy SA Snell rated helmets! As a former Paramedic I have seen many cheap helmets crack, split or completely come apart and kill the wearer! Isn't it worth and extra $100 or so? Ask Ken Etter if he's glad he had a good helmet! Jim
Ken's helmet was pretty useless when the steering column went up under his chin guard, Just sayin.
The tracks I run at have lot's of shutdown area even for a 128 mph car and if it's on fire I have other thing's to worry about. I will be looking for M2010 though.
2009 V/SA Record Holder
Old 09-15-2011, 11:31 PM   #2
Leroy Duran 7118
Default Re: M2000 helmets R I P
are the SA2000s done after this year as well?
Leroy Duran 7118 STK, ST, SG
Leroy Duran 7118 is offline   Reply With Quote
Old 09-16-2011, 12:09 AM   #3
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Yes they are.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 09-16-2011, 05:43 AM   #4
james schaechter
Liked 1,443 Times in 302 Posts
I think getting the best quality helmet that you can afford is key to reducing risk in the case of an unplanned event. The problem is that you don't know how bad it will be or when it will occur. If you can't afford a good helmet, skip one race and that is enough money to easily purchase a nice one. Yes even a SA2010.
There are many many good choices, I would pick the one you like and then go to your favorite seller. I researched a new one last winter and decided to get a simpson superbandit sa2010. I then went to my favorite place for speed equipment. ( they support our Heartland series hint hint) I asked him, he got me the helmet I wanted at a discount too.
If your goal is to get the minimum allowable helmet and keep it as long as NHRA will allow, maybe you should rethink your approach. Even slower stockers are going pretty fast. It doesn't seem that fast until something bad happens.
I remember being at Bowling Green in I think 2001. A stocker had the transmission lock up or hit reverse in the shut down and lock up the rear tires. It turned 90 degrees in front of the car in the other lane. The car was going around 115. I saw it cart wheel on the guardrail and end up upside down filled with gasoline. We had a hard time getting him out of the car and the driver definately wanted out.
The point is, don't skimp. I buy a new helmet every 2-3 years. It becomes part of my racing budget. I am not rich, and don't throw money away, but I do spend some money on a helmet and my other safety equipment. It is not that you have other stuff to worry about when you crash. It is that you want to eliminate or reduce risk so that if you do crash, you are less likely to be crippled or dead. I wondered about the SA2010 rating for years. I was told about the potential for a flash fire whether it be from fuel, oil or electrical etc. It doesn't take much to start a fire. It just seemed that it was a relatively easy thing to upgrade to.
When it costs a few hundred bucks in fuel just to get to a race, it seems silly to skimp on a helmet. If you spend $400 on one and keep it 4 years, that is only $100 per year of your racing budget. Just my opinion.
James Schaechter 3163 STK
Old 09-16-2011, 07:51 AM   #5
danny waters sr
danny waters sr's Avatar
Thumbs up Re: M2000 helmets R I P
I remember being at Bowling Green in I think 2001. A stocker had the transmission lock up or hit revierse in the shut down and lock up the rear tires. It turned 90 degrees in front of the car in the other lane. The car was going around 115. I saw it cart wheel on the guardrail and end up upside down filled with gasoline. We had a hard time getting him out of the car and the driver definately wanted out.
When it cost a few hundred bucks in fuel just to get to a race, it seems silly to skimp on a helmet. If you spend $400 on one and keep it 4 years, that is only $100 per year of your racing budget. Just my opinion.
Very good advise .............
Old 09-16-2011, 08:12 AM   #6
Jim Kaekel
Liked 536 Times in 110 Posts
X2 Very well put, Jim. You even made me think about it as I've got a SA2000 ready to expire. Some of the circle track racers I work with tell me "are you nuts?" when I tell them I wear an open face helmet.
Jim Kaekel 3836 STK
Old 09-16-2011, 01:43 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Great advice! As I said before, ask Ken Etter how glad he is he bought a good helmet! The pictures of whats left of that red Demon is sill available on this site. Everyone's SA2000 helmet will be no good as of 1/1/12 and will have to be replaced. Even a FWD Stocker racer needs a good helmet when you think they are capable of running 90-110mph and have no roll bar! Jim
Old 09-16-2011, 02:44 PM   #8
Philip Saran
Liked 14 Times in 11 Posts
Great advice! As I said before, ask Ken Etter how glad he is he bought a good helmet! The pictures of whats left of that red Demon is sill available on this site. Everyone's SA2000 helmet will be no good as of 1/1/12 and will have to be replaced. Even a FWD Stocker racer needs a good helmet when you think they are capable of running 90-110mph and have no roll bar! Jim.
And Ken Etter's helmet was a full face and he still broke his jaw amoung
other parts of his body.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 09-16-2011, 07:00 PM   #9
Dustin Ward
Liked 4 Times in 2 Posts
Even If you believe your car is too slow to warrant a good helmet, Remember in the other lane may be a 4000# 140 MPH Cobra Jet.
Dustin Ward is offline   Reply With Quote
Old 09-16-2011, 09:09 PM   #10
Chad Rhodes
Originally Posted by Dustin Ward View Post
Even If you believe your car is too slow to warrant a good helmet, Remember in the other lane may be a 4000# 148 MPH Cobra Jet.
fixed
Chad Rhodes 2113 I/SA
