Old 09-02-2011, 06:37 PM   #1
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Default Re: Shifting heavy S/St car on Stop.....
We were racing too I did not see a reason to go out and get any data at 5000' + of air. Cant see it as real useful but maybe I am wrong. We both know I have no clue what I'm doing anyway.
sst7250 is offline   Reply With Quote
Old 09-21-2011, 09:17 AM   #2
85transam
Trying to figure out running a throttle stop and have a couple questions hopefully you guys can answer. We have a heavy car (3500) that will run 10.30s. From what I have read I figure we should have the stop on very early ( .3-.5?). My main question comes from the fact that we have a three speed tranny. When is it best to shift into second gear, and I assume we should do both shifts on time? Thanks for all the help in advance.
85transam is offline   Reply With Quote
Old 10-02-2011, 09:32 PM   #3
gnicholson
Liked 4 Times in 3 Posts
not many guys throttle stop race with a 3 speed . that doesnt mean it cant be done.you should be able to shift into 2nd quicker than if it had a glide because you still have some gear multiplication. i would try .5 on the 1st shift and start with the 3rd shift right before the stop comes off say 1.5. this is just a guess on my part and you will have to experiment with timer settings as well as stop rpm adjustments
gnicholson is offline   Reply With Quote
Old 11-10-2011, 09:35 PM   #4
RacingRicki
Sponsor
RacingRicki's Avatar
i think you will have a hard time running the number shifting on time with that setup. you will probably have to set your rpm really high.
RacingRicki is offline   Reply With Quote
