Interesting , I have yet to see a suspended TAD car. My buddies TD is a slip car, so far best of 6.09 231 but its an ex TAD car.
Of course you're right about TAD, but you asked about TD/SC. There, at least today, suspension rules. I bet if you went down the top 50 in national points in those two classes you'd find little more than a handful of un-suspended cars. You can do it, and have a lot of fun racing, but hard to be consistent and win a lot.
We just moved from a hardtail to a suspended car, and there is nothing that would take me back. The difference is amazing: the car is a pleasure to drive and vastly more consistent.
Chris Williams 6304 SC, TD, ET |
#3 | |
If you have ever seen a TAD shaking the tires you would understand why no one tried a suspended car.(They some times shake hard enough to knock out the driver temporarly!)
The comments that Chris has offered are correct for TD/SC where consistency is king! But if you study the comp eliminator dragsters they are interested in all out performance and don't use suspensions because of the weight they also use the smallest rear tire possible to reduce rotating weight and are willing to give up some consistency for all out performance. Since their class are weight per CI they try to get to the class minimum which is several hundred pounds less that your typical 1800-2000# S/C dragster.
Bill Baer 3391 SC, 339B SC, QR |
#5 | |
![]() When we ran comp we had a Boz C/ED and then a Clack B/ED so I know a little about them. |
Offroadr
I guess this brings up the question is there a limit to horse power you put to the track in a suspended car frankly I don't know. I Like Chris have see mid to low 6 second suspended cars I havent seen a 5 second suspended car but I'm sure there's probably one out there. If you friend's car is making enough steam to run Oh's and shake the tires I'm thinking he is probably better off with a proven hard tail combination however he's going to have trouble getting the consistency he needs to get the car to run the number round after round. In the past when I was only bracket racing I would try to get paired up with the way fast guys because I knew they usually couldn't hit their dial in consistnetly and I knew that I could.
True dat!
#8 | |
There are combinations of what was listed above also, and the triangulated 4 link he mentioned is sometimes referred to as a swing arm and is also made with two shocks.
