I have sold my TD and have bought a stocker. I am selling all parts in order to change my inventory to help my stock efforts. ALL ITEM ARE MAKE OFFER. If it's reasonable it's yours.
ATI Turbo 350 with ATI Treemaster 8 inch converter both have just came from Abruzzi for freshen. In ISA car now. Trans has reverse VB and has some other mods. Chrome dial mount with flip a dial for flat tray 3 pair Strange gold brake pads for rear setup 9 inch Comp Cams BBC Stainless roller rocker arms. PG shorty trans rear cover, hardened input shat, locking dipstick, pro tree brake with aluminum pan and Shield. HAS BROKEN PLANETARY Flatlander chute and pilot in Stroud packing bag Aerospace Calipers and brackets 9 Inch Ford Biondo electric shifter solenoid spring type Carbon dragster scoop insert. Dominator Aluminum intake GM 458520 Frameworks pro dragster shifter no cable 3.90 gear Ford pro gear big pinion 3 runs. MSD Cranktrigger dist. Chevy slip collar fits stock - 10.2 deck Simpson -15 suit 2010 date 1 run size large. Team Jegs jacket black pants Simpson -5 suit same as -15. Large team Jegs Oakley gloves 3.3/5 team Jegs Small Simpson low cut shoes size 9 black. Like new Impact neck braces black. 1 new 1 used. Hybrid Pro Rage head and neck restraint. With sliding tether add on. Impact Champ Alcohol helmet with built in sock and sealed shield. 1 run perfect. Silver size is same as large will get exact. TWO used crank trigger pick ups Contact VERNONMCKAGUE@HOTMAIL.COM 573-680-0428 I am going to sell all so don't be shy. All I can say is no Contact VERNONMCKAGUE |
