Old 08-15-2011, 04:01 AM   #1
79transam
Default suspension tuning... help me please
i run slide a links, i just put 9 way caltrac shocks on it and it helped my 60' but it still spins bad. this video is last weekend there is 160lbs of weight in the car, 10psi of tire pressure. i dont know if i need stiff sidewall slicks, or more pre load or whats up. any help will be greatly appreciated..
79transam is offline   Reply With Quote
Old 08-15-2011, 04:04 AM   #2
79transam
Default Re: suspension tuning... help me please
here is another video from a different track
Old 08-15-2011, 10:13 AM   #3
69Cobra
Liked 2 Times in 2 Posts
I just watched the first set of videos not the second but from what I saw you a have a couple things going on there. First would be to get more front end travel one way or another. Second would be to make the front react quicker, free it up some. Then in the rear, the body is rolling over on the passenger so there you have two things. First you need to get the car to leave straight. An air bag on the cheap side or a anti-roll bar to do it right. Along with that the rearend is not separating (planting the tire). This could be from the rearend being in a bind and/or the shocks set to stiff and/or way to much preload on the slide links. Hope that helps.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 08-15-2011, 08:31 PM   #4
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Work on the front suspension. Do a search on this site, it'll fix you right up.
Joe Marcinowski 3377 STK
Joe Marcinowski is online now   Reply With Quote
Old 08-16-2011, 12:48 AM   #5
Hudlow66
Hudlow66's Avatar
Video one looks as though the slicks needed a little more air. They wadded up pretty good and spun at the hit. The second looked to be slightly better. It actually rolled out and let loose about a foot / foot and a half out. Dont know if you changed something between those two passes. (now this was the first set of videos) There seems to be some binding in the rear suspension. There's no movement either way. (I personally don't know how those 'slide-a-links' work.) Only thing moving is the sidewall of the slick. I looked at the second set of videos and they all seemed fairly consistant. Low pressure and wadding up the tire.
Most importantly, don't go changin' a bunch of stuff at once. Ive seen many that do and all it does is lead to frustration.
If I were to make a suggestion, I'd probably try going up with the pressure. If you're running 10 now, jump 'em up to say 11.5 and see what kind of pattern they're leaving. If they're still nice and flat and it helps on the line, you can bump 'em up a little more.
Keep us updated on the changes you make and how the car responds.
Phil Hudlow 6678 (S/C, S/G, ET-PRO)
Hudlow66 is offline   Reply With Quote
Old 08-16-2011, 10:20 AM   #6
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
It would be easy to say that you could put a few turns of preload into the passenger side bar but im not sure that will work. Slide a links have a urethane bushing so maybe have a look and see of they are showing signs of wear and rebounding. Front suspention is where you will find the most help...make sure its loose and moves freely through its travel. I would check the front shocks out as well. If you have the factory rubber snubber in the upper front control ams take them out...that will give you some more front end travel. Do you still have rubber bushings in the front leaf spring eyes? If so change to a Moroso solid or just order a set of Calvert Split-Mono's and forget about it. I played with a set of old super stock springs for a year untill it started cork-screwing like your car is doing and then that was it....changed to the whole Calvert setup and never looked back. A comment was made about an Air Bag but thats gonna be tough in a leaf spring deal...ive never seen an air bag on a leaf spring car. Good luck and let us know how you make out.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 08-21-2011, 06:27 PM   #7
79transam
ok here is my update. went out today and tried 14lbs of air, it blew the tires off, went to 10lbs of air and it started hooking. then as the day went on it started going back the other way and spinning again. it wasnt bad but it was spinning. to answer some of the questions on here. i have moroso trick front springs, 90/10 lakewood shocks in the front, the rear is the comp engineering slide a links with calvert 9 way adjustable shocks. it likes the lowest setting. the rubber bushings are gone in the leafs and it does have the alum bushings in. im thinking about taking the rubber snubbers off of the slide a links and machining a alum bushing for them. it hooks then unloads. i was gonna play with the pre load some today but since last week was rained out i had free entry into the race and not enough time to test and race.
Old 08-21-2011, 11:47 PM   #8
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Replacing Lakewood 90/10's with Calvert 90/10's help my front suspension.
Ron Gusack is offline   Reply With Quote
Old 08-23-2011, 01:25 PM   #9
69Cobra
X2
Originally Posted by ron gusack View Post
replacing lakewood 90/10's with calvert 90/10's help my front suspension.
Kris Rachford
C/S 3032
Old 08-23-2011, 02:50 PM   #10
Jim Cimarolli
Liked 166 Times in 46 Posts
Cool Re: suspension tuning... help me please
Also looks like you could use some more pinion angle.
The rear suspension is not separating, its either too tight or not enough pinion angle.
Jim Cimarolli is online now   Reply With Quote
