Old 08-01-2011, 01:44 PM   #1
rpmrcn7616
Default rear wheel back spacing on a 71 nova
trying to figure out the right wheel spacing for a 71 nova gonna run a 10 inch rim building it to be a stocker it has a 10 bolt rear end in it with drum brakes
rpmrcn7616 is offline   Reply With Quote
Old 08-01-2011, 07:10 PM   #2
James Perrone
Liked 1,835 Times in 428 Posts
Smile Re: rear wheel back spacing on a 71 nova
15 by 10 .... 6 inch back space
Not east to do...Takes some work$$$
james perrone 1290 STK
Old 08-01-2011, 07:31 PM   #3
rpmrcn7616
Default Re: rear wheel back spacing on a 71 nova
why is it hard to do?? or is it that its hard to find a 6 inch backspace?
Old 08-01-2011, 07:37 PM   #4
Jim Cimarolli
Liked 166 Times in 46 Posts
James is right, it can be done, but it takes a bit of work. First off, if you are going to use a radial tire it will be easier for sure. Besides that, you will need to relocate the bottom point of the shock, and also massage the leading and trailing edge of your fenderwell as well as to cut off the inner lip of the outside fenderwell.
Have fun!
Jim Cimarolli is offline   Reply With Quote
Old 08-01-2011, 07:44 PM   #5
rpmrcn7616
Have fun!
i currently am running a 8 inch rim with a hoosier drag radial 30x9x15 ive already folded in the outer lip and everything clears ok but everyone i talk to says for stock i should run a 10 inch rim car is just gonna be a small block car
Old 08-01-2011, 09:53 PM   #6
Joe DeMarzo
Liked 120 Times in 11 Posts
Listen to both James's they have had Nova's in stock for a long time. Also not sure what SB combo you are running but you really don't need a 10 inch tire if your suspension and weights are right.
Joe DeMarzo 1317 STK
Old 08-01-2011, 10:02 PM   #7
Mickey Whaley
james doesnt know anything about nova's hello?????
Mickey Whaley is offline   Reply With Quote
Old 08-01-2011, 10:10 PM   #8
Todd Boyer
Liked 6 Times in 5 Posts
I've heard a stock racer say that you don't really need a 10 inch wheel with a stocker tire, they say it doesn't matter much between 8" 9" or 10" - just their experience and opinion.
Old 08-01-2011, 10:13 PM   #9
1299
Liked 54 Times in 12 Posts
ya he built the wrong one lol right james
1299 is offline   Reply With Quote
Old 08-02-2011, 02:35 AM   #10
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: rear wheel back spacing on a 71 nova
I went from a 10" to 8" wheels on my car no trouble? I run Hoosier 9x30 lightweight C06 94" roll out. (I'm thinking 8" rim will be fine)
