Liked 192 Times in 83 Posts
Greg.. give MT a call.. they have that size and I know they work..
Liked 20 Times in 12 Posts
Greg, I have talked to Mike about the Phoenix Radials and I am going to try a set. Have you ever compaired them to anything else? I mean how do they wear, how are they in hot weather etc. I believe that you run Douglas and Valdosta allot correct? Thanks.
Robert |
Robert,
Brandon runs Douglas and SGMP in the Summit series. We tested these tires in '02 on our stocker when they were introduced and they were significantly faster than the Hoosiers. Since then Hoosier came out with a lightweight radial that may be comparable to the Phoenix Other than the durability and consistency of the Phoenix radial the personal service you get from Mike Crutchfield is second to none. Mike is a racer who goes to the racetrack and understands the tire business. Brandon has 155 passes on the Phoenix radials on his car now and his first hint of tire spin came on that 155th run. |
