Old 07-13-2011, 12:54 AM   #26
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Default Re: Track is making up rules
Originally Posted by Toby Lang View Post
If they will let you dial 12.00 they have to give you some allowance to breakout.
I have an idea. Why don't they change the rule to say if you run faster than 11.90 you are DQ'd after one warning? Or if they are so concerned about cars running in the 11s, make the minimum dial 12.10 and a DQ for anything under 12.00.
What do you think about that, Phil?
-Toby
That's what I was thinking since I believe the intent is to prevent 11.50 cars from running in a 12.00 bracket. Tossing someone for going 11.99 is nuts. It is the tracks perogative to set rules as they see fit but quoting a rule from another class to justify a bad decision is also BS. This wasn't a track management decision BTW but something the head tech guy and race director came up with at the last event.
I don't race in this class but think those that do should have had some say before **** started hitting the fan. JMO!
Dale Posnick
Dinsdale is offline   Reply With Quote
