#15 |
Liked 392 Times in 153 Posts
12:00 is the quickest you can DIAL, not the quickest you can RUN.
You dial 13:00 and run 12:50 and I dial 12:00 and run 11:51. I win because; (1) I dialed within the parameters of the class (12:00 minimum) and (2) you broke out worse. Unless it is stated in clear and concise wording that "you cannot run quicker than minimum dial" it is horsecrap. On the other hand there is also the "it's my racetrack and I'll do what I like, you don't like it then leave" mentality which never helps. |
