Old 07-02-2011, 10:32 AM   #41
Charles Rainey
Default Re: High oil pressure?
Carl
You cant be 51 years old. You been doing CNC crap for more years than that. Yep HeHaw
ED
I, just as you do, dont want any more than 40 psi but I do it differently. Like I said, many ways to skin a cat. I use a slightly larger pump and then dump extra back to pan down the back of the pan. I never see a drop in pressure at the end of a run(unless I run 3 quarts). I use a set screw on the spring to set the pressure to dump. I mill a slot so that if pressure builds up, as the unloader moves back it will uncover more slot and dump to pan. It takes very little HP to turn a oil pump dumping to pan, but it does take HP to turn a pump dead heading to bypass in its self. Man it doesnt mean I know any more than you do, I just do it differently. Probably same end result
cheers tall
Charles Rainey is offline   Reply With Quote
Old 07-02-2011, 01:40 PM   #42
carl hinkson
Liked 18 Times in 10 Posts
Originally Posted by Charles Rainey View Post
Carl
ED
Only have been CNC machining blocks for 11 years or so.
carl hinkson is offline   Reply With Quote
