Old 06-15-2011, 07:48 PM   #1
magnumv8
Default Re: Would A Drive By Wire Car Be Allowed to Race ?
Ed....Bluetooth, WI-FI, 802.11 are all available to access data and monitor a vehicles functions with the proper interfaces and apps that are also available,with the micro electronics some of these are small enough to integrate into an ignition box or an ECU.....the technology has been out there for years (F1 has been able to do this for a long time but they aren't supposed to use it, same with INDY cars....monitoring is OK,tuning on the fly is not even though they can).....auto-tuning and or self calibration to a preset ET (once set) is pretty easily done for someone intent on doing it.....
D L Rambo.....
magnumv8 is offline   Reply With Quote
Old 06-15-2011, 08:20 PM   #2
Liked 10,750 Times in 2,235 Posts
Chuck of C&W try looking for a program that looks very similar to cruise control. You know you tell the computer how fast to run and the computer adjust throttle position, fuel delivery, and timing to trace a run.
Remember F1 had to pass a rule to have the driver shift the transmission.
Most if not all things are possible if enough money is spent in the right place.
Old 06-15-2011, 08:45 PM   #3
Ed Wright
Ed Wright's Avatar
D L Rambo.....
The ECU has to be compatible for it to work. Monitoring is one thing, that is what scanners do. Manipulating the ECU's code, espscially on the fly, is another. F1 ECUs are one thing, Ford ECUs, FAST & Bigstuff3 are another. They do not support wireless (like Bluetooth) control. Looking for an interface connected to the interface cable (where you connect the laptop for tuning) is not hard to watch for. Could an ECU, like F1, be built to do that? Of course. Is one on NHRA's accepted list? Nope.
Ed Wright 4156 SS/JA
Old 06-15-2011, 09:02 PM   #4
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
Get over it Larry....I could cheat if I had a pink Mopar...too..lol
Drive by wire is not desirable...for us anyway....it's just the way the new cars come.....if you run a factory ECU....you get drive by wire....if not...you use a cable....end of story....ask Bo....lol
CBS is offline   Reply With Quote
Old 06-15-2011, 09:09 PM   #5
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Charley, I'm confused, my 93 Mustang Cobra H/S car is nearing completion, and where should I set the throttle to prevent being blown off the track because I don't have a supercharger ? I'm thinking with all that horsepower that you found on the dyno, that if you get bumped into H/S, all my efforts will be for naught.!!!, and how would would I feel then. LOL!!!
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 06-15-2011, 09:16 PM   #6
Chris1529
Liked 70 Times in 29 Posts
I'd set your throttle at 200% if I was you!
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 06-15-2011, 09:20 PM   #7
JHeath
JHeath's Avatar
BTW,Charley, your car rocks !!
Jerry Heath
I/S '93 Cobra
Old 06-15-2011, 09:27 PM   #8
Chris1529
I really like to see the 93 Cobra's. The engine I run in my Mustang is the GT-40 engine which is basically the same as yours with the exception of a carb and 1.6 rocker arms. Are you going to use a 5 speed trans?
Chris Bowman
1984 Mustang GT350
Old 06-15-2011, 09:34 PM   #9
JHeath
JHeath's Avatar
No, I will use my Jerico for the now.
Jerry Heath
I/S '93 Cobra
