Liked 325 Times in 50 Posts
If we don't have any other technical subjects, then I'm going to bed as the 4 AM departure comes early.
Jeff Teuton 4022 STK |
Good luck Jeff!
Ed Wright 4156 SS/JA |
Liked 633 Times in 88 Posts
Larry do a little more research before you post. Your not helping your cause. The ford factory fly by wire system cannot be changed while going down the track. If you start a run 70% throttle you end a run 70% throttle. Drive by wire is not traction control in drag racing. Yes you could cheat using fly by wire, but you can also cheat using a carburetor and a home made MSD box. So what is your point? If you think new cars are the only thing holding you back from winning race's build one. Then you can have that unfair advantage and all that prize money.
Fords don't spin anyway.
Charley Downing 3548 STK Last edited by Charley Downing; 06-15-2011 at 07:36 AM. |
Liked 198 Times in 79 Posts
Charley, how can a car that runs 9.50 and a car that runs 10.60 have the same 60 foot time if they don't vary or control (gain) the throttle opening during the run?
Mike Fuller 396 STK 3961 SS |
Liked 10,690 Times in 2,227 Posts
800 hp, 600ft/lbs torque, 42% rear weight, 9" tires, hot track, and no spin.
Its just a physics problem! |
1.80 low gear in a 2 speed trans and a big blower SS
2.40 low gear three speed trans and a small blower STK CJ are turds off the line and then the blower takes over. There only 330 CI Mike the CJ make all there power from 500 ft to 1320ft. Ask anyone that has ran one and they will tell you at 1000ft you don't think they are getting there and then all at once they are going by you. any other questions.
Charley Downing 3548 STK Last edited by Charley Downing; 06-15-2011 at 08:51 AM. |
Would the drive by wire, traction controle, run tracing, wheel counter, CJ 's be allowed in Super Gas?
Ford spent the money, dotted all the I's and cross all the T's, did the R&D, and bought the rest with cars and trucks. Get ready to see them in the winners circle, a lot. Bottom line CJ's are great race cars!!!! |
#8 | |
Guest
Posts: n/a
I called brad Charlie cause they look similar, sorry Brad.. :/ It's been awhile since I've seen Charlie. A little calculus will tell is what's really happening with the throttle manipulations going on, right? Thank you Newton. ![]() |
