Old 06-07-2011, 08:57 AM   #1
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default Re: Jackstands, Please Use Them
That is a bad deal. Sorry about your friend CP. Jackstands have a very real need. Cinder blocks, and logs have no place under any car. I saw logs under a truck in New Orleans a couple yrs ago. Guy asked me why I took his picture, working on his truck. I said so some one can identify you later...
2894 STK
Old 06-07-2011, 02:04 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Hate to hear about your friend. I have seen people go to crawl under car with no stands,ask what about stands,they reply just gonna take a second to do whatever they are doing,I say that is longer than it takes for car to fall,usaully will get stands then
Mike Taylor 3601
Old 06-07-2011, 02:29 PM   #3
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Very sorry to hear about ur friend. I watched a lot at E-Town Nats that did not use stands on the race cars.
Bob Bender 144 O/SA
Old 06-07-2011, 02:44 PM   #4
Run to Rund
Liked 54 Times in 27 Posts
I get worried about jackstands if they are extended too far; a side load or one failing (who knows how strong that cast Y shaped top to the stalk is?) can topple the rest of them. I also use 15" or 16" wheels welded edge to edge to get 12" to 16" height and put them under the frame with wood to get the right height and more friction against the frame sliding if something goes wrong. It is a balance of the opposing factors "there is no end to concern" and "you can't be too safe."
Old 06-07-2011, 05:15 PM   #5
Chad Rhodes
I've got some 16"x12" treated timbers in 24" lengths that work great stacked on top of each other. No possibility of failure
Chad Rhodes 2113 I/SA
Old 06-07-2011, 05:32 PM   #6
mtkawboy
Liked 54 Times in 18 Posts
As a 16 year old kid I had a bumper jack fall over on a Lincoln when I was changing a starter. I was trapped and could barely breath. Fortunately a lady came along and I was able to tell her how to jack it up enough to get out. Lesson learned big time, I was extremly lucky to be able to get enough air until someone came along. If I weighed what I do now Id be dead !
mtkawboy is offline   Reply With Quote
Old 06-07-2011, 06:18 PM   #7
Stock726
Liked 13 Times in 9 Posts
I lost a friend of mine in 1986 who thought that concrete blocks were good enough. He was working alone and wasn't found until the next day.
It is a shame this has to happen over and over.
Stock726 is offline   Reply With Quote
Old 06-07-2011, 06:29 PM   #8
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: Jackstands, Please Use Them
Anything can fail! Concrete, wood, logs, anything. How many times have you seen cars braced up off the ground by old wheels and tires set on top of each other? I have seen cars fall off of jack stands due to improper usage, but never seen one break or mechanically fail. Just like anything else, you must know how to properly use a tool! The jack must be on sturdy ground and have a good purchase point with equal weight distribution. Jim
Old 06-07-2011, 08:04 PM   #9
Winklovic
Winklovic's Avatar
Liked 29 Times in 8 Posts
This happened here just yesterday. It's always a good idea to have help when doing heavy lifting.
http://www.winnipegfreepress.com/bre...123336218.html
Charleswood man dies after backyard mishap
By: Staff Writer
Posted: 06/7/2011 7:50 AM
WINNIPEG - A 57-year-old Charleswood man has died from injuries he sustained after a rock slab fell on him Monday evening.
The man was performing yard work around 7 p.m. Monday and appears to have been moving a heavy object, possibly a piece of concrete, when he fell and became pinned underwater in a pond in his backyard, police said.
Family discovered the man later. He was taken to hospital in critical condition, but died Tuesday.
The man's name has not been released. Foul play is not suspected.
Brent Mazur
Winnipeg, Manitoba
Winklovic is offline   Reply With Quote
