Liked 5 Times in 3 Posts
I have a alum intake here Chevy SB part # 3823481 what's it fit? I can't find it in the blueprints. Holley bolt pattern. Oh it has the oil fill tube in it too.
Liked 70 Times in 29 Posts
http://www.classracer.com/classforum...ad.php?t=12608
look through here Greg. Still clear as mud though.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 333 Times in 180 Posts
that manifold was used on US Army personell carriers from the late 50's to the early 60's---they originally came with a carter wcfb carb on a 283 engine I think it was a M135 carrier if my memory is right---comp
correction it is a M113 not a M135 carrier
Liked 4 Times in 4 Posts
The M113 was diesel powered while the smaller M114 was powered by the 283 Chevy rated at 160hp.
In Viet Nam the m114 was a scout version and was underpowered and under armored and mostly gone by the late '60's. I remember racers scouring military junkyards looking for those motors. JimR
Jim Rountree |
Liked 129 Times in 59 Posts
Before the M113 Armored Personnel Carrier (APC) got the Detroit Diesel, it had a small-block Chrysler (old poly-sphere). They would flood out at the worst possible times, and the engine was so tight against the right side bulkhead you had to be a contortionist to change plugs. I was very glad to see the A1 model fielded!
Lew (former Field Artillery)
Lew Silverman #2070 "The Wagon Master" N/SA |
And on the 113 you can't forget the deluxe plywood "swim panel" to keep the front slope from turning vehicle into a submarine.
Liked 574 Times in 212 Posts
I believe the "early" 113's had a Chrysler 361, not a small block. the 114's were 283's. They sounded fast, but weren't. ha ha
I spent plenty time in a M113. I could even sleep in it while it was moving. Just hold on to the strap and nod away. |
