Old 05-24-2011, 07:59 AM   #1
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: Sewer smell while driving
I cant believe someone had not came up with a diaper jab That was funny
DIAPERMAN is offline   Reply With Quote
Old 05-24-2011, 09:02 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
Default Re: Sewer smell while driving
i am having the same issue. When I flush the toilet when the air conditioner is running I get a foul smell. Seems to be only when the A/C is on.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-24-2011, 10:29 AM   #3
BlueOval Ralph
Banned
Do you also have a shower?? I you do it could be that the trap in the shower is draining when you you flush I had that problem in my Prevost a couple large glasses of fresh water in the shower drain did wonders, it would also happen when the holding tanks were drained. Also it does not hurt to put fresh water in any trap after draing holding tanks
Just a thought
BlueOval Ralph is offline   Reply With Quote
Old 05-24-2011, 12:45 PM   #4
Mike Pearson
Thanks Blue Oval Ralph. That makes good sense. I will try that.
Old 05-24-2011, 06:21 PM   #5
DIAPERMAN
The shower is grey water and stool is black tank I think I found problem access panle in bathroom there is a releif valve that runs in the side top of black water tank the one-way valve on it is bad but Fleetwood dose not show on parts list
Old 05-24-2011, 07:27 PM   #6
sc180b
What is on the nontank side of the relief valve? Is the relief valve threaded into tank or is part of the tank? Is the odor in the bath room or in the front area of coach?
sc180b is offline   Reply With Quote
Old 05-25-2011, 01:52 AM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Hey Mike, quit pooping in the A/C unit! Jim
Old 05-25-2011, 08:07 AM   #8
DIAPERMAN
1/2 inch line comes out of the side top of the black tank and runs up in wall the line that goes out of valve I dont know where it goes smell comes up front when driving ,but it is in bath area also any ideas
Old 05-25-2011, 09:26 AM   #9
sc180b
Make sure both black and gray water tank vents are open, you can run water down both vents with a garden hose from the roof. Check under the kitchen sink there should be a syphon style vent that comes off the top of the drainline. In my coach it is stuck way back in the corner and hard to see. These vents have a spring and flapper in them and they can stick in the open position. Not sure what the 1/2" line would go to, and the valve in that line is most likely a check valve to keep odors from coming out when line is empty. This line is most likely an overflow from something not in use all the time.
Old 05-25-2011, 12:02 PM   #10
Jeff Stout
Liked 704 Times in 281 Posts
If you have a wash machine it also has a j-bend trap that goes dry from sitting. It has a trap door on the outside of motorhome behind washer and I would have to fill with water at entrance where hose empties into
