Liked 21 Times in 6 Posts
Thanks I saw those
Not sure what make coach you have, but I have had the same issue in my last two motorhomes. I tracked the problem down in both of them to the in house syphon style vent the manufactures use on the drain lines for the sink in the cooking area. This style vent is spring loaded and opens when water goes down the waste line. The smell is from the vent not closing completely allowing odor from the gray tank to come back up and out of vent. The vent is normally located in the cabinet under the sink. The vent is easly replaced and should thread off, no cutting or glueing involved.
Pope |
Liked 880 Times in 311 Posts
I couldn't resist.... Have you checked to see if your Diaper is full?
Adger Smith (Former SS) |
I cant believe someone had not came up with a diaper jab That was funny
Liked 1,939 Times in 583 Posts
i am having the same issue. When I flush the toilet when the air conditioner is running I get a foul smell. Seems to be only when the A/C is on.
Mike Pearson 2485 SS |
Banned
Do you also have a shower?? I you do it could be that the trap in the shower is draining when you you flush I had that problem in my Prevost a couple large glasses of fresh water in the shower drain did wonders, it would also happen when the holding tanks were drained. Also it does not hurt to put fresh water in any trap after draing holding tanks
Just a thought Last edited by BlueOval Ralph; 05-24-2011 at 10:32 AM. |
Thanks Blue Oval Ralph. That makes good sense. I will try that.
#8 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
1/2 inch line comes out of the side top of the black tank and runs up in wall the line that goes out of valve I dont know where it goes smell comes up front when driving ,but it is in bath area also any ideas
