#12 | |
Liked 1,821 Times in 413 Posts
Jeff, the current configuration of Stock Eliminator, especially with 9" tires, does not offer the necessary safety margins for 150+ MPH cars, it just ain't there. I'm not going to advocate a change that's going to cause a marked increase in accidents. Like I said, make A/S and A/SA both 7.0 pound classes, move the new cars to FX classes, say A thru D, with A/FX being 7.0 pounds and D/FX being 10.0 pounds, then adjust the HP and weight rules on the classes to make the new cars fit and work well. If necessary, give them a 10" tire and some safety upgrades. If they're going to run in Stock Eliminator, even in their own FX classes, they need to be held to the point where a really fast pass is a 9.0 at around 150. Once they get factored to where they don't fit the FX rules to keep them at that limit, send them to Super Stock. Honestly, even FX classes with 10" tires is not the proper solution. Thoroughbred factory race cars belong in Super Stock, there was a reason they were put there to begin with, and the reason is still valid and still applies today. I'd advocate the FX classes merely because it's as close as we're going to get to the proper and correct solution. I want to see the new cars race, I have no problem with them existing and being raced, it just needs to be done right. The factories and NHRA can promote them in any class, they don't have to be in classes they don't really fit, running all over the cars that belong in those classes, in order for them to be impressive and promotable. The new cars would be just as impressive, and easy to promote, in stand alone FX classes, or in Super Stock, where they belong.
Alan Roehrich 212A G/S |
