Old 04-28-2011, 08:26 AM   #28
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Header coatings - Part Two
Rich, I tig them.
I use a 2" Rolock scotchbrite wheel to remove the heavy coating on the area being welded.
I've found cranking up the gas flow ,and using ER70-6 wire instead of the more common 70-2 works to give a clean weld on a coated tube.
