Old 04-19-2011, 10:33 PM   #1
Pat Joffrion
Liked 6 Times in 2 Posts
Default Red Light Answer
As a racer, I did not understand how just dropping a few RPM's could cause a red light.
Once I built No Problem, I discovered just how delicate the staging beams really are. After serveral customers were red lit by the tree (in the same lane), I took a Cajun approach. I used a dragster wheel to light the stage bulb, then back it up a hair-width, and the red light came on as the tree was activated.
This happened on more than one car, but all were using trans-brakes. In some of the instances, the reverse gear overrode the forward 1st gear, resulting the vehicle to back up a FRACTION OF AN INCH, which caused the red light. I witnessed the same occurance in footbrake cars that staged very shallow.
The solution was installed five years ago when we ordered the CompuLink Stage-Loc beams. Not a single reverse-action red light since then when using autostart. However, in the Jr. Dragster younger age groups, we still use a manual start because some of the kids would get auto-started in a timed-out situation. Some of the kids get the red light from the rocking of their small front tires. It's just the way it is.
Our Stage-Loc system will allow a driver to back up three inches once the tree is activated (after the last bulb is lit for 1/4-second). But you must remember that in order for Stage-Loc to be in effect, auto-start must also be in use. HOWEVER, even with Stage-Loc, if you light both bulbs first, then back out by just a fraction after your opponent has lit his stage bulb for 1/4 of a second, the computer fires the tree without seeing you in the beam, and you are red.
It cost me about $5,000 for the Stage-Loc upgrade, but it was worth the money. Not a single ***** chewing since it was installed. I can prove it to any driver... if you stage real shallow, just turning your steering wheel a little bit will turn on the red. Just backing off the converter will turn on the red. You need to check with each track to enquire if they are using the CompuLink Stage-Loc. If they don't have it, or are not using it, you could be SOL (and red).
I hope ya'll now know how the system works.
Pat Joffrion is offline   Reply With Quote
Old 04-20-2011, 12:56 PM   #2
Walker4108
Walker4108's Avatar
Liked 7 Times in 1 Post
Default Re: Red Light Answer
Great info Pat. Thanks!
Walt Walker
Walker4108 is offline   Reply With Quote
Old 04-20-2011, 05:09 PM   #3
Mike Gray
Mike Gray's Avatar
Liked 685 Times in 196 Posts
So did the camera flash cause Mason's red light?
The next frame in the video shows his red light come on.
I assume the starting line reads from the outside the same as the downtrack lights.
Name:	red light2.JPG
Mike Gray is online now   Reply With Quote
Old 04-20-2011, 06:31 PM   #4
Pat Joffrion
Quote from response by Mike Rice: "The shallow stage deal is very real, especially without the StageLoc program."
From Reading Mike's reply, it appears that Stage-Loc was not used. I was under the impression that all national event tracks had it installed years ago. However, it has to be set to be "ON" for each category in the tower computer.
If it was not turned on (per Mike's reply), then someone in the tower screwed up! Since the stage beam are recessed at least six inches inside of PVC tubing with less than three-eighths of an opening, I don't believe the camera flash could in any way reflect into such a small hole to reach the receiver.
Conclusion: Without Stage-Loc operating, the slightest movement of the front tire more than likely caused the red light. Kind of sucks to have the software disabled! I would recommend that someone needs to verify that it is enabled for stock and super stock at each race.
Old 04-20-2011, 07:02 PM   #5
Mike Gray
Mike Gray's Avatar
This seems like an intresting subject. I can't figure why the red comes on at the second yellow when the car appears not to move at all, it doesn't appear to even be loading the convertor. When I watch the video over a few times in full screen, you can see the flash reflected on the pavement. Since he has polished or chrome wheels it seems possible the wheels reflect the light causing the eye to read that the car has moved.
If this wasn't possible why do a lot of cars have the ugly flat painted front wheels.
Old 04-20-2011, 07:16 PM   #6
Bernie Cunningham
Liked 52 Times in 17 Posts
As far as I know, that type of sensor is no longer used, as in where light reflections or flashes would cause them to 'switch'.
These days the units are a sender and receiver across the track and must communicate with each other to 'switch'
Bernie Cunningham 7053 STK
Bernie Cunningham is offline   Reply With Quote
Old 04-20-2011, 07:37 PM   #7
Pat Joffrion
Mike,
I didn't fully answer your question, so here goes:
The Stage-Loc and starting beams read only from the center of the starting line ... Not from the outside (as is the case down track). Actually, there is no outside lens for the Stage-Loc beam!
From looking at the photo, it appears to be impossible for the flash to go through the vehicle. Before I built my own track, I used to put shoe polish on the front rims because the starter told me that the bright sunlight might' ve caused my red light.
I found out the reason after investing millions. You guys get for free. Trust me, I know how it works and am glad to help answer your questions. Now, if someone can just explain to my wife and I the reason we have to bury our son tomorrow...
Chatting on this forum helps to get my mind off Philip's death, at least for a few minutes. Thanks for listening.
Old 04-20-2011, 07:55 PM   #8
Mike Gray
Mike Gray's Avatar
So when the funny cars take out the 1/8 mile and finish line foam blocks there is not just a reflector in the blocks but a receiver or sender?
Did it use to be just a reflector? maybe that's where the idea of wheel reflection got started.
Camera flashes for an instant are very bright, I hate the annoying flashes from overhead strobes at NBA games that are triggered by the photographers camera.
If I watch a replay in slow motion it will white out my tv screen.
Old 04-20-2011, 08:12 PM   #9
Mike Gray
Mike Gray's Avatar
Originally Posted by Pat Joffrion View Post
Mike,
If the starting line beams read from the inside it doesn't seem possible that the light from the flash caused a false reaction. He would have to have been in really deep or really shallow to cause it to trip since the Stage-Loc was not on. (Assuming they have Stage-Loc at Pomona)
I raced up and down the West Coast and found all kinds of ways to loose but this one was new to me.
On another note - I am truely sorry to hear of the loss of your son. My son is only 13 and I can't comprehend what your family is going through. My condolences and exta prayers.
Old 04-20-2011, 08:18 PM   #10
Jeff Stout
Liked 704 Times in 281 Posts
I dont know the equipment at Pomona but what I know the reading device is in the middle on the starting line and when the car is staged it would block the camera flash that is shown in the video. The camera flash may have shined onto wheel but its the wheel facing the outside portion of the lane and would not interfere with the sensing beam. Now the rest of the increments down track have a reflector in the middle and the reading sensors are on the outside of the lanes.Doesnt solve the problem here but I think I would rule out the camera flash. As Don described his problem in WY I would have liked to have seen the tree activate again as the Camaro was still staged when tree was cleared just to see if car was at fault.Just a thought: if the beam is .030 in diameter and the wheel rolls just enough lets say .030 and keeps beam from crossing track and the car would move backwards (somehow?) say .001 then the beam is now uncovered and would register as if nothing was on starting line and go red. Cant be seen with naked eye. Sounds pretty far fetched but maybe.
