Old 04-06-2014, 08:16 AM   #1
james schaechter
Default Re: Racepak for stick cars
Originally Posted by Damn Yankee View Post
Jim, we were looking at our T5 case and most likely will have to mount the sensor to where it will read off of the cluster shaft as well. We are using a Racepak Sportsman box and will have to see if it will convert to the main shaft speed as well.
Mark provided us with his pattern for the jerico. If you can make a collar and drill and tap the case, it works great! I am sure that the same principle will work. You will have to see where it can all fit in there! It helps to have a friend with machinist skills. Easy work for them to figure out. I like being able to figure out when and how long the clutch slips. If you do that and if you have data from kyle carruthers clutch dyno, it makes life easier as far as clutch tuning is concerned. Especially if you have to adjust for heads up vs. Elims or track conditions.
James Schaechter 3163 STK
Old 04-06-2014, 07:30 PM   #2
Damn Yankee
Thank you James
Damn Yankee is offline   Reply With Quote
Old 03-01-2015, 11:38 AM   #3
Cam
Cam's Avatar
Originally Posted by Todd Hoven View Post
Has anyone put this sensor in a Gforce G-101 4 speed? Is there a good way of doing it?
Lots of good feedback on the Jerico installation but I'm still wondering if anyone has put the magnetic collar on a G101 countershaft?
Cam Chowen
6067
1994 Camaro C/S
Cam is offline   Reply With Quote
Old 03-01-2015, 05:16 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Contact Bubba at G-Force, I am sure he could tell you if they have, or what is involved.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-01-2015, 08:30 PM   #5
Mark Madison
Liked 32 Times in 9 Posts
I'm selling my SC-1000 racepak unit. Please see my add in the racecar parts section. Thanks Mark Madison
Mark Madison is offline   Reply With Quote
