Old 04-16-2011, 08:30 PM   #1
Mark Madison
Liked 32 Times in 9 Posts
Default Re: Racepak for stick cars
I use 3 inputs , Engine Rpm, Input shaft/ Clutch Rpm & Driveshaft Rpm
Is the tire spinning or the clutch slipping while using one sensor for both.
Mark Madison
Mark Madison is offline   Reply With Quote
Old 04-17-2011, 01:44 PM   #2
Todd Hoven
Guest
Posts: n/a
Has anyone put this sensor in a Gforce G-101 4 speed? Is there a good way of doing it?
Old 04-17-2011, 08:52 PM   #3
Dave Casey
Liked 797 Times in 165 Posts
Mark, what racepak unit do you use?, and does anyone know if the correction can be put into the sportsman and the v300 ?
Thanks,Dave
Dave Casey 1330 STK
Old 04-17-2011, 09:05 PM   #4
Dave Casey
Monty, by having the engine rpm and the input rpm, you see a true graph in every gear, all the time, another words you see proportionally how much the clutch is slipping. The driveshaft rpm increases continually and it is harder to see the true slipage. Comp and prostock cars have it easy putting the sensor right on the input because mainly they have more room to get the sensor in the bellhousing astheir bellhousings are much deeper than ours and have a different input setup.
All that being said, I am no expert on this data stuff as I don't have any in my cars yet, I just have an understanding of it some what.
Dave
Dave Casey 1330 STK
Old 04-17-2011, 09:23 PM   #5
Mark Madison
Dave, I use a RacePak SC1000 with the latest upgrades, not a v300 but good enough. You can try Right clicking the clutch icon and the "scaled buffer channel parameters" window will appear. To adjust for the countershaft ratio adjust raw data value "B" . for your M/D ratio.
Old 04-18-2011, 12:32 AM   #6
Dallas Kelly
Liked 85 Times in 21 Posts
Default Jerico modified for Racepak
A top and bottom loader Jerico modified for Racepak sensor by re-machining the cast-in fill plug boss.
ID:	6955   Click image for larger version
ID:	6956   Click image for larger version
Dallas Kelly is offline   Reply With Quote
Old 04-04-2014, 03:46 PM   #7
Damn Yankee
Default Re: Jerico modified for Racepak
Dallas, did you machine this yourself (magnet collar on the shaft) or did you farm it out to someone else ? We are class rule restricted to T5's and Tremec's and I am want to mount a sensor for the input shaft data logging on our G Force T5. Because of the transmission design and no one making a sealed tapered bearing, G Force prefers not to help us with this project
Damn Yankee is offline   Reply With Quote
Old 06-25-2012, 03:03 PM   #8
GEORGE PETERSON
Liked 11 Times in 6 Posts
Todd,
G-Force can supply a bearing retainer fitted with a bung that will accept the sensor. They can also supply the necessary sealed input bearing.
George Peterson
D/S 4448
GEORGE PETERSON is offline   Reply With Quote
Old 04-05-2014, 12:49 PM   #9
Jim Hawkins
Liked 115 Times in 35 Posts
I have a input sensor on my jerico in my ss/i car that is exactly like the one Mark built for his. I did alot of research and no one makes a kit to do this, including jerico. There is no way we could see to mount it to read directly off the input shaft. My machinest made a slip collar with a magnet that installs on the cluster. We drilled and tapped a 1/2 hole in the case and used a 1/2 bolt with the center machined and tapped to accept the sensor. My trans. is a older bottom loader and was easy to set up with that bottom cover removed. I use a computech system and it will convert the main drive ratio to 1:1. I have a new jerico trans. that was just finished last week and they installed the collar and drilled the case for me. The new trans. does not have the bottom cover so need to install sensor and collar as the trans was being built. This has worked well and have seen a few others done the same way.
Jim Hawkins is offline   Reply With Quote
Old 04-05-2014, 11:15 PM   #10
Damn Yankee
Jim, we were looking at our T5 case and most likely will have to mount the sensor to where it will read off of the cluster shaft as well. We are using a Racepak Sportsman box and will have to see if it will convert to the main shaft speed as well.
ID:	23246   Click image for larger version
Name:	g force case.jpg
