Old 04-14-2011, 06:47 PM   #17
HawkBrosMav
Liked 302 Times in 73 Posts
Default Re: What??????????
This situation epitomizes the reason I believe blocking the tree should not be allowed... its a safety issue. If you can't see the starter trying to stop a race(regardless if it happen in this situation or not) or the reds flashing how are you supposed to know if there is an issue down track??? I know some aren't on the helmet and you can still see a lot around you, but not all of them are... I'm not arguing this because I believe they have any advantage...if you have to block the tree to be competitive so be it.. but the fact that someone could be in a dangerous situation because of the use of a "blocker" to me should make it illegal due to safety...
Brad Hawk
