Decided to give up running a 9in Radial on my Trans AM. Anything over 3400 on the 2-step it blows them off. What compound are yall running? Tire size will be 29X10 or 10.5.
CJ Perry 9931 PCA-1 |
Liked 89 Times in 28 Posts
What were you using?
The tires I use are: Hoosier CO7 in a 13.5X31.5 lightweight tire. Trans brake Super Stock car. Hoosier CO6 in a 30X9 radial. Foot brake Stocker Hoosier DO5 in a 30X9 bias. Foot brake bracket car You should be better off with a bias tire. |
Liked 354 Times in 120 Posts
I started runnig 10.5 radials liteweights on my superstock 3200lb trans brake car chiped at 5700. Thats what patterson had on his ka car also. Tom
Tom Meyer 5240 SS Stock ??? |
I also run 10.5 light weight, 3400lb superstock, chipped at 6500.
Glenn |
Liked 11 Times in 8 Posts
What 10.5 lightweight are you referring to?
Joe Buchanan SS/BX 3117 |
Hoosier
#7 | |
Liked 4 Times in 3 Posts
Call or e-mail us for some help if you like. My own car 60 foots mid 1.30's on 9 inch Goodyear radials launching at 6200 off a trans brake.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
Liked 150 Times in 43 Posts
Hoosier 9X30 Radial D07 Compound 18-20 PSI
I agree with Alex. We have run this tire on our two crate motor cars with no issues leaving at 3500 rpm on the two step for years. In fact I cannot even remember the last time that the tires actually broke loose and spun. Good luck
Aaron Allison 395 STK, 395 SS, 3395 SC |
#9 | |
last weekend we went on the 1.39's the first outing with the brand new setup. The first 3 passes I was on the 2-step 3000 and it hooked fine. car hit the wheelie bar every pass. tried to bring it up to 4400 and of just blew the tires off. C07 30X9 radials 92.5 roll-out. All passes were made at 20psi. I'm happy with how it did leaving lower. The car does weigh 3500lbs so it's not gonna leave but so hard with my cheap setup. Were gonna give the 9in Radials another shot. I think on an IHRA prepped track it will hold a higher launch.
Liked 13 Times in 9 Posts
Gotta remember that you haven't had the car out in the awhile... make sure none of the shocks went bad. And drop the tire pressure down to 17 psi. Are the tires new?
