Ron
On the flex plate shield I don't run one but I'm under 135 mph and still have stock firewall and floor. As far as the cost, that depends on you. Just guessing I'd say about $1000. up to $1500. doing it yourself. You will want a d-box with timers for the stop. Something else is the diaper, next year they will be mandatory ! Last edited by Bob Verwold; 04-08-2011 at 08:17 AM. Reason: change |
Liked 7 Times in 6 Posts
I had no idea about the diaper, what a PIA. How many oil downs happen in 10.90 cars? Biondo has too many boxes, Mega this and Mega that. Which one do you like? Which T-stop? The car has a Dominator on it.
Liked 1,877 Times in 577 Posts
Jamie sothers has a dedenbear disk stop complete for sale on here sounds like a good deal, i like #1 stop stuff. you cant go wrong with a mega 450, but any box with t-stop timer will do....
#4 | |
Liked 13 Times in 3 Posts
Chuck |
#5 | |
They mount to the header bolts, with straps, right? Aren't the straps in the way if you have to change plugs? Will they go on and off with a stock Nova subframe? |
Dennis at DRE can fix ya up and there not as bad as you would think..
217-763-6352 |
Great thread, all this info from a "is it legal" question. Well I drove to PA and brought back a tube chassis mustang II.(Detroit) My shop is super busy right now put I hope to get to it in the next couple of weeks. My fab guy wants to update the car and keep the 7.50 cert but not sure it matters for what I want to do with it though. The car was built a LONG time ago but has really good parts on it. So the next question is this: I have parts lying around the shop to build a 515 bbc should make plenty of power but I purchased a new deadenbear TS with the second linkage from a guy on here about a year ago for a 4150 style carb.(all new in box) This will hurt power but I don't think that it will matter, it should still run plenty under, but do you guys think it will be just a consistant with the smaller carb on a bigger engine.
a side note I do machine work for some pretty good S/SS guys --way tooo high strung waving temp gauges at 7:30 in morning and draining oil out to go faster. I'm looking forward to being a duck in the 90 towards the end of the season. (for a few races any way) Thanks Joe |
I've heard plenty about how much more consistent an under carbed engine is. You can also get 4150's that flow 1200 cfm.
