Old 04-02-2011, 08:58 PM   #1
jasondearduff
Default Re: solid front bushings. Camaro
i just used a thick washer and a shorter bolt, looks to be the common practice on most of the cars i see.
jasondearduff is offline   Reply With Quote
Old 04-02-2011, 09:12 PM   #2
BadCamaro
do you place the washer on the underside of the subframe (in between subframe and bolt head) and bushing in the middle and nothing up top?
BadCamaro is offline   Reply With Quote
Old 04-02-2011, 09:27 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I believe the bushing is sandwiched between the sub-frame and body - big washer on the bottom.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 04-03-2011, 03:57 PM   #4
rustbucket79
I've installed those bushings on 2 different Camaros over the years. First one I did on the cheap, IIRC I used some steel plate to back up the factory washers, last one I built thick washers out of aluminum bar stock on the lathe. IMHO these kits should come with the correct bottom "washers" as well as the bushings. They aren't a complete kit in my view.
rustbucket79 is offline   Reply With Quote
Old 04-03-2011, 05:45 PM   #5
BadCamaro
Thanks for the reply guys. Im getting ready to install new leaf springs, CE subframe conn, and CE solid bushings, Ive pb blasted the bolts since december, but doing it all in one sha-bang!
