Hi I race a 69 Nova with 9'inch tires and a slaper bar setup..Question is my 60ft average is 1.58 would I gain anything better if I get a set of Cal Tracs is it worth the investment any input.
Thanks DJ |
Liked 91 Times in 51 Posts
It took us quite a while to make repeatable gains with just the Cal-Tracs. And when the track would change, we would get a hiccup.
After we bought the leaf springs the 60's were more predictable. It really is a "system" in my opinion. Buy his rear shocks also...you do not need double adjustable shocks on a leaf spring car. Calvert's front 90-10 shocks also helped free up the front some more. Clark |
not to take over the thread but what is the normal ride height everyone is using on a 69 or 70 model nova? 1 inch higher, level, or 1 inch lower. (split mono leaf style)
Josh Edwards 752A SS/GM, SS/BX, I/SMA |
Liked 509 Times in 117 Posts
I use the one inch higher in mine for the ballast we have to carry.
68 Chevy11 327 F/S |
Liked 10 Times in 6 Posts
DJ, I agree with Clark. If you switch, buy the split monos, bars and the shocks. I have had good results with their front shocks, as well. As to weather it would be worth it, are you having traction issues now?
We use the cal-tracks an 9-way adjustable shocks and the 90-10 on the front, all from Calvert Racing. On our 69 G/S Camaro. Running a 4 speed. Saw alot of improvment just with the cal-tracks. I would recommend using 10" rim with your tires if the will fit..... Usually a 1.53 60' times. Going to try the new shocks out this weekend.
Liked 13 Times in 10 Posts
the cal tracs are a great "system" as the others have said, the real issue will be just how good you have the car working with the present slapper bars, when i had my 69 camaro my slapper bars were home made and worked really well,what improvement you see will depend,i would recommend them in any case
Thank you all for your feed backs!
DJ |
