Liked 129 Times in 59 Posts
Great idea, Wade!
Now let's see who steps up to make it a reality! Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Good luck with that one..lol rule book says subject to change on a LOT of the pages...
DW your" un-official"......
Danny Waters, Sr / 73 Duster "340" |
Liked 546 Times in 94 Posts
A rulebook is subject to interpretation by the tech officials and racers alike. I think it's impossible to make wording that would cover all situations. It's like the tax code...all interpreted in different ways. And it's all legal until you get caught! lol
Julie Jordan 7549 STK |
Liked 30 Times in 17 Posts
Wade, I think some of the Tech guys live for the "gray areas" of the rulebook. What can you do......get a letter of approval for every nut bolt and washer on your car?
I like the concept that you propose and I think Wesley could handle that job, but he doesn't deserve the grief. It's going to take a real glutton for punishment and a strong personality to take that job. TP Last edited by Pedigo Perf; 03-10-2011 at 12:10 AM. |
Liked 17 Times in 7 Posts
I think it would be tough for sure. The way Wesley explained it to me "If the rule book does'nt say you can.....you can't". This would alleviate the gray area because the rule book would have to say you can directly. The issue with that would be, the ability to be innovative. And in most cases at the upper end of innovation means $$$$. I just feel that if a racer was to bring something new to the table that had not been seen by tech before, it would be nice if a supreme ruling could be made. And if it was accepted, a revised/adjusted rule could be put into the master book and/or online for all tech officials to view. This would just be an attempt to keep everyone on the same page as far as rules enforcement!
Wade Mahaffey |
#6 | |
But.....if the 2011 Drag Packs can use a Ford 9" does that allow all Mopar racers that option? If Tech is getting spread too thin then maybe they need to pick their battles and start by the using the word "any" a little bit more in the rulebook. When was the last time someone collected protest money? Just curios. TP |
As far as safety there should never be any grey areas, but from a mechanical standpoint there are so many different cars and combinations I sure it is very difficult to cover any and all situations. I think NHRA has done as much as they can when it comes to engine specs for each combo ... from runner volumes, valve sizes, stroke, bore, piston/rod weight, (things you can measure) but after that some things you just can't measure and put in the rule book. Those other specs are left up to interpretation by each tech. I am not saying this is right or wrong, but those are the facts. Hence, left coast, right coast rules.
What I would like to see for any 'ruling' or interpretation by any tech person would be that they should fill out some kind of form or paper work defining the situation or infraction, what they ruled and why and file it in a NHRA data base for future reference. Then they could review this data base info and come up with more of a base line for setting the rules. Over time they could minimize the 'grey areas'. But this takes time and effort and I am not sure they have the staff or time to do it.
Chuck Beach 3340 STK Last edited by Chuck Beach; 03-10-2011 at 10:45 AM. |
#8 | |
Liked 866 Times in 235 Posts
The "9"inch housing some Drag Pak cars are using only utilizes the housing stamping . It has a different mounting flange that accepts the Mopar 8 3/4" aluminum chunk [good luck getting one!], not the Ford 9'" chunk.
Liked 16 Times in 11 Posts
Wade, Very good idea but Glendora, now Indy and there lies another problem. Where will Danny be ? The way I see it 2 of the best, Travis Miller and Wesley Robenson have been belittled, forced to change their decisions and had their pay cut. When you have 2 tech men with the knowledge of these 2 have why not use them ? Instead they are pushed farther away. Wesley had more info on HP for the AHFS but was removed from the committee. I do not think NHRA can handle a national scale rule book when it comes to Stock and SS, there pick of the week check at national events is about as far as they can go. Real tech done at Indy often is changed by Danny, if the head guy runs the ship and continues to do so Stock and SS are doomed, the rules have been diluted to a point of no return.
Bob Pagano A/SA |
#10 | |
Liked 7,716 Times in 1,738 Posts
