hi folks ,i have a question, in 1970 a w-30 olds ,which class this car can it run in category stock ,i know than in 1966 the big 442 olds can run b/stock ,it is the same with a w-30 1970 olds or what is the best class the w-30 can run ,thanks
looks like D, E, F but i could be wrong...
Dusty Lowell #1773 STK F/SA |
Which class would they have run in 70-72?
Liked 10 Times in 10 Posts
The 1970 Olds 4-4-2 455/360 HP in 1970 would run G/S.
The 1970 Olds 4-4-2 455/370 HP in 1970 would run in F/S. Those classes were from 1970/1971. The cars weighed in at around 3675 lbs. In 1970 at Dallas, the 1970 Olds 4-4-2 W-30 ran in F/Stock. And the National Record was 12.01 Last edited by Paul Ceasrine; 02-27-2011 at 03:26 PM. |
thank ,Paul ,so it's impossible to run a stock 455 motor , only with headers and slick with a 442 w-30 ,4 speeds and 3.91 with a spectacuar run at 11.79 ,what do you think about that .
hey ,Paul ,, also why olds run in 66 run b/s and olds run f/s in 70
Liked 165 Times in 59 Posts
just to chime in ,,you would be hard pressed to run that # ,but there is a racer who runs a green 70-71 olds with a 4 speed set up (350 i think ) that could give you some insight on what you need to do with your car i dont have his info but he runs division 1 ,,if i can find the info i will repost gmonde
Liked 180 Times in 55 Posts
Isn't Bureski's W-30 in E/SA?
Would it be S Murray.............
MB |
Boss351,
The weight break factors changed over the years. Oldsmobile 4-4-2 as per year 1965,,,,,,B/S 1966,,,,,,C/S 1967,,,,,,B/S 1968,,,,,,D/S 1969,,,,,E/S 1970,,,,,F/S It fell into the 9.50-9.99 wt/hp from 1968 and up. In 1965, 1966, 1967 the class wt/hp was 9.50 - 10.59 Super/Stock 1967,,,SS/E 1968,,,SS/F |
