195 comp. ported AFR heads solid roller 2.58 / 2.65@ 50 Victor Jr. 2" spacer with a hp 950 Just under 11.1 compression. 1 3/4 headers
You don't have enough gear, nor do you have enough low gear in the transmission. You don't need to try to "fudge" anything by telling them you're putting it behind a Super Stock engine, besides, when you give them the specs, they'll know. You need a 4.88 or a 5.13, and about a 1.90 low gear.
Alan Roehrich 212A G/S |
#3 | |
#4 | |
Liked 759 Times in 379 Posts
That said, the quick fix is more gear or a 3 speed trans and a shorter tire. Here's an example of a 3160 lb. footbrake launched ride slowed every week to run low 10.0s with a sbc under the hood backed by a 1.80 1st gear glide that leaves with a best 60 foot to date of 1.27 and has run 9.77 @ 138+ with a manifold having less plenum volume than yours and no 2" spacer ![]() Last edited by 1320racer; 02-21-2011 at 02:53 PM. |
Thanks for your input also. I will try the shorter tire to see if it likes it. Then add more gear if it does.
One more question. If I change the gears to 4.88 and it leaves harder will I not see a big increase in the top end rpm because I would get there quicker? I dont want to be spining it higher than 7400 up top.
you'll be turning 2-300 more RPM in the lights than you are now
#8 | |
400, 10" 4.56, 7300, 7500, old school 830/4150, Brodix/HVH. The converter and carb were not selected for optimum 60 foots, ETs and MPH.
Whats the stall? Thats a good running car. I will try and run mine without the spacer and see if it helps. I'll be at Etown in a few weeks for the Corvette challenge and give it a shot.
