Old 02-06-2011, 01:30 PM   #1
slwryde
slwryde's Avatar
Thumbs up Re: inconsistent 60ft
It is a big tire. My thinking was that the big tire would help with consistent 60ft times on a variety of track conditions. I choose the DOT tires because the car is street legal and I like to drive it on the street once in a while. I had no idea traction would still be a problem.
Rear gears are 5.13
I have changed instant center from 48" out and 10" up
to 59" forward and 9" up with no noticeable difference in results.
I have had the bottom 4 link bars "nose up" trying to achieve as high an
instant center as possible. I am starting to think maybe trying to adjust
the bottom 4 link bars so they point down slightly in the front to see if that will help.
Also I have ordered a set of slicks. When I took the DOT tires off I noticed 3 perfect muddy water stripes inside the wheel tubs!! directly above the grooves in those DOT tires.
I really appreciate every ones advice.
slwryde is offline   Reply With Quote
Old 02-06-2011, 10:15 PM   #2
trikbag406
Default Re: inconsistent 60ft
I'm with 'L78 Nova',Im thinking transmission temp.Im no powerglide expert,but I know the 400 turbo in my Vega was built without enough clutch stack clearance (I admit,my own doing),and as the day went on,I saw slower 60 ft times,as well as slower ET's. It turns out I was dragging the forward clutches in my trans after it got hot,and the hotter it got,the worse it was.Just my experience.-Lew.
Tranquility base,the Vega has landed...
trikbag406 is offline   Reply With Quote
Old 02-10-2011, 09:53 AM   #3
Bill Baer
Rear gears are 5.13
I think you will find that the slicks will fix 90% of the problem in my experience big street tires aren't as good as even little drag slicks.
One other thing to keep in mind is engine coolant temperature you need it to be consistent if you want the 60' & ET's consistent.
You might also want to get someone to video record your launches, paint a white stripe on the side wall and pay attention to the inital hit, if you can see the line going around it's hooking, it the line is a blurr then it's not! If the tires spin on the inital hit your 60' and in some cases your reaction times will be inconsistent.
Old 02-11-2011, 11:14 AM   #4
bottombulb
Do you run an electric water pump and electric fan?
bottombulb is offline   Reply With Quote
Old 02-12-2011, 12:30 AM   #5
slwryde
slwryde's Avatar
I have an electric fan. The water pump is a stewart.
Old 02-12-2011, 07:09 AM   #6
StripeHOG
do you have anyone on the starting line that can verify you are in the groove on every pass???? IMO thats probably whats happening!!
StripeHOG is offline   Reply With Quote
Old 02-13-2011, 09:18 PM   #7
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
inexperienced driver combined with a new car and there's far too many variables here to determine exactly why the car is in consistent in 60 feet.
I'd suggest having an experienced racer watch you from the moment you roll into the water through staging and launch.
I also suggest setting the tires at a psi known to work and not touching them for the rest of the day.
Others things...
length/time of burnout needs to be the same every pass, stage at exactly the same temp every pass, launch at exactly the same RPM every pass, get more seat time.
Again, way to much tire!
Old 02-13-2011, 09:53 PM   #8
pmrphil
Liked 401 Times in 154 Posts
Hi, if you don't have a trans cooler, the buildup of heat could cause the problems you're showing, and I agree with the others, slicks, and leave lower.
Phil Molski
PMR Performance
S/C 1623
