Old 02-06-2011, 09:51 AM   #1
james schaechter
Liked 1,453 Times in 303 Posts
Default Re: What to add in radiator?
If you leave the water in the radiator for general racing or between races, it is good to dump some anti rust and water pump lube in. It is cheaper than the purple ice and redline stuff. It isn't something to help cooling like those are, but it does help protect your radiator and water pump.
Some areas have really bad iron and hard water deposits in the water so keep that in mind, especially if you don't drain it after the races each day.
James Schaechter 3163 STK
