Old 01-20-2011, 06:41 PM   #2
Default Re: Front end alignment
All the positive caster you can get, zero camber at the ride height the car is at when it is on a pass, and about 1/16" to 1/8" toe in. This should be done with the driver's weight added to the driver's seat while the car is being aligned. You're trying to get to zero toe and zero camber as the car goes down the track, for minimum drag, and the positive caster makes the car want to go straight, because anything close to zero toe tends to make a car want to wander at least a little.
