How would a Super T-10 stand up in a sml-blk SS/H Camaro?? I know the " clutchless" styles are best but I have access to a T-10 set-up complete.
Chris |
Liked 520 Times in 132 Posts
Chris obviously the better choice is a Jerico or GForce. It will be cheaper in the long run to pay more up front for Jerico etc. That said I ran a Super T10 pro shifted with Liberty Gears behind a 65 Chevy II 283 for 3 seasons before it broke. Everyone said it won't last 3 runs. That was also with the old style clutch 2800lbs shifting at 9400. My Jerico shifts so nice compared to that T10 ill tell you that. Ed
Banned
Liked 235 Times in 110 Posts
Jerico will save you money in the long run. I had a SS/I Camaro 350 years ago (1977-78) and before we went with the P/G ran a Super T-10 and it didnt last long. Then ran a "slick shifted" Chrysler A833 I got from Larry Kopp out of his H/G Corvette. It lasted much longer but still gave it up after a couple of years. If you cant afford the cluthless Jerico at least go with the one used in stockers
Liked 1,438 Times in 301 Posts
I would think it would be like a tootsie pop. 3 licks and you would get to see the inside!
James Schaechter 3163 STK |
I would like to be against you in a final round of a National event!
Jeff Lee 7494 D/S '70 AMX |
#6 | |
Seriously, If you have a good Super T-10, I think you would be much better off selling it, and putting that money towards a proper race transmission. When I first built my M/Stock Mustang, I too thought that the factory T5 would be good enough to get my feet wet, unfortunately, the wetness came from oil from the broken T5`s! By the end of that 1rst year, all I had left was a T5 with a bent mainshaft, and the remnants of 2 other damaged transmissions. And that was with a lower classed Stocker, a decent SS/H car should be about 2 1/2 seconds quicker than my Mustang was at that time. Buying a couple of used Jericos was money very well spent. The Jerico in my Mustang has been as reliable as an iron anvil , and the other trans in my 10.0/132mph bracket car went 10 years before it needed any repairs ($300.00 worth of 3rd gear parts.) Plus with a Jerico (or G Force) you can get many different gear ratios, including changing individual ratios, where the ratios in a ST10 will NOT be even close to optimal.
#7 | |
![]() The King Is Back ~~~~~~~~~~~~~~~~~~~ Last edited by KingReptile; 01-08-2011 at 03:09 AM. Reason: typo |
#8 | |
Liked 780 Times in 194 Posts
When I raced my A/S Camaro, aftermarket transmissions were not legal so I had to use a T10. A production Super T10 was good for about 10 passes before something broke. I used an iron case AS9 model of the T10 (the version used in the mid-late 70's Camaros, Corvettes and Firebirds) with a 9310 nickel gear set from Liberty with a 2.99 first gear, a billet side cover and a machined steel bearing plate in the rear. Such a transmission cost about $1500 in 1985 dollars, and I carried two with me wherever I went. Rarely did I break a gear, but that was due to a very light clutch and 9" tires. However, I budgeted $1000 a year for transmission maintenance for sliders, hubs, magnafluxing, new dog rings, gear replacement, etc. plus time to disassemble transmissions for check ups after every 20 passes. Two years after I sold the car, aftermarket trans were made legal. (Had I know that was going to happen, I might not have sold the car.) I built an SS/C '66 Corvette after that with a Jerico and put over 100 passes on it with no transmission failures. (Driver failures, but nothing to blame on the trans.)
All that to say that you can race the car with a Super T10, but it will not be as much an enjoyable experience. I wouldn't do it. |
#10 | |
You have to have a car first. LOL
