Old 01-06-2011, 11:16 AM   #2
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
Default Re: Racepak IR Temp Sensor
We use the same sensor in our DATAQUEST system. It can be used to monitor track, but also used to monitor the Burn Out tire temperature. Our system uses its full color touch screen display and can be set up to warn driver once tire reaches correct temperature during burnout. This allows for consistent tire temps and can match desired temp for the current track conditions. The track temp is not the only temp that matters, it is only 50%, the tire temp is the other 50%!
www.AltronicsInc.com
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
