Old 01-03-2011, 09:47 AM   #1
fredjohnston
Liked 55 Times in 14 Posts
Default Re: Can I remove my dash vent?
Originally Posted by Chad Rhodes View Post
you can't run a racepak dash in a stocker to begin with, but otherwise yes. The firebirds have been putting gauges in the AC vents for quite a while
not correct on the part about not being able to run a racepak or other dash in a stocker.
fredjohnston is offline   Reply With Quote
Old 01-03-2011, 10:45 AM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 282 Times in 78 Posts
Place the racepak display in front of the gauge cluster that is original.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-03-2011, 11:24 AM   #3
Jeff Lee
Jeff Lee's Avatar
So they no longer have "full stock dashboard including instruments, fresh air ducts and controls must be retained" in the NHRA rulebook?
See Stock / Electrical / Instruments.
Jeff Lee 7494 D/S '70 AMX
Old 01-03-2011, 11:32 AM   #4
Ed Wright
Ed Wright's Avatar
Yep, I had to put the AC/Heater controls back in my dash for SS. Guys with the Firebirds do put gauges in their AC vents. I'm probably the only one not to. I see cars with the Racepack dash on the collumn in front of the factory cluster, don't think you can pull the cluster.
Ed Wright 4156 SS/JA
Old 01-03-2011, 12:10 PM   #5
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
I am retianing my factory cluster. It is a lot more difficult to put the race pak in front of the stock cluster than in front of the heater register. Also I have been told (not from NHRA) that I could remove the heater controls because the car is a heater delete from the "factory". Maybe I should call NHRA tech for clarification?
Thanks,
Larry
Larry Curtis is offline   Reply With Quote
Old 01-03-2011, 01:39 PM   #6
Rory McNeil
If a car is indeed a factory "heater delete" car, then why does it have any heater controls in it?
NHRA 6390 STK
M/S 85 Mustang
Old 01-03-2011, 01:54 PM   #7
Larry Curtis
Your guess is as good as mine.
Old 01-03-2011, 03:09 PM   #8
Chad Rhodes
Not what I was told.
Chad Rhodes 2113 I/SA
Old 01-04-2011, 02:34 PM   #9
Larry Curtis
Chad,
Just got off the phone with NHRA and the Race Pak dash is leagal. Removing the vents is not.
Larry
