#11 |
Liked 227 Times in 74 Posts
Wade are your pulley numbers backwards or is it just me. I have found pulleys for my crank with ratio of 2.26 and 2.10 for my altenator pulley size. Thanks guy's for the helpjust need to make brackets now.
#12 |
Liked 39 Times in 5 Posts
Is there any benefit to underdriving the alternator?
Norm Webber |
#13 |
Liked 883 Times in 237 Posts
Wades numbers are right for a Stocker that needs no real alternator output.
carburated Stockers run faster with a fully charged battery and an alternator that is really just along for the ride.
#14 |
I agree with Tom and Wade.....That how we run all our stockers (Although not the truck we use to tow them Home).
#15 | |
Liked 8 Times in 7 Posts
#16 |
Liked 460 Times in 91 Posts
Me too.......................
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#17 |
I should have mention this is a stocker. Wade and Bob are you guys just running off the battery and not running any electricity to the altenator?
#18 |
We use Denso Alt. and still have 13.8 to 14.2 volts above 2,500 with above ratio.....I like all the voltage I can get with MSD. We are seldom below that RPM even in Pits.
John Irving |
#19 | |
Liked 3 Times in 1 Post
I did have a racepak on for awhile, after peaking at 14.4, it stayed there for the duration of the run. We do have to have a working alternator, hooked up and charging as per rules. Wade O |
#20 |
My alt. turns on at approximately 3000 to 3200 rpms and puts out 14.2 volts.
