Old 12-27-2010, 07:51 PM   #1
bigshow2966
Liked 181 Times in 56 Posts
Talking Re: 1970-1972 Chevelle frame...what will get me bounced?
The Buick GS cars are supposed to have extra bracing in the rear of the frames. They also had a support bracket that went from the frame to the mounts for the lower control arms.
bigshow2966 is offline   Reply With Quote
Old 12-27-2010, 09:01 PM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: 1970-1972 Chevelle frame...what will get me bounced?
is that the same ones that tie the upper and lower control arm mounts together?
that was a factory deal for ALL A bodys.
must be a reason for 'em cuz just about every chevelle/montecarlo/elcamino i've ever owned (a bunch) had 'em..
Old 12-27-2010, 11:21 PM   #3
FED 387
Liked 333 Times in 180 Posts
Edelbrock & hotchkiss perf supposedly made/make some triangular stiffening plates that helped stiffen the frames on 454/455 engined cars---Supposedly all 454/455 used the A body convertible boxed frames whereas a sedan or 2dr ht used the standard C or non boxed frames
Old 12-28-2010, 10:16 PM   #4
bigshow2966
These were a single strut that went from the front lower control arm bolt to the frame. My buddy's '70 Stage 1 car had them, my small block Skylark did not.
I do not recall seeing anything that tied the top and bottom mounts though. I have not been under my Buick for a while though.
Old 12-29-2010, 07:54 AM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
This is what the GM "A" body rear upper, and lower ca braces look like.....
http://www.musclecarmetal.com/catalo...er.asp?id=1552
They did not come on all "A" body cars, just the 4-speed, or big block, or cars with the "hi- performance suspension option......
Old 12-29-2010, 08:18 AM   #6
Tom keedle
Tom keedle's Avatar
yep, that's the ones BUT my wifes old 68 300 chevelle had 'em...but you're correct, not ALL A bodies had 'em.
seldom seen them on 64-67's.
was there a TSB for them somewhere back then?
i dunno.
heard it was a retrofit kinda deal for some issue back then and it just went into assembly line cars...
60K 6 cyl/3speed...bought it from the original owner..
