Old 12-12-2010, 09:31 PM   #6
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: 8.5" rear end - 68 Camaro
Originally Posted by Greg Reimer 7376 View Post
Buy the spool,axle and bearing kit and do it right the first time.(option 2) You can't believe what damage sudden rear end destruction can do.You never save in the long run when you have to do it over. Also, you need more gear--4:88's or so.
I called my friend with the axles and he offered the Moser 12 bolt out of his 68 Camaro since he is putting it back on the street and has another 12 bolt that will be putting back in it. Coincidentally, it has 2 year old 4.88s and the light weight spool. He said he went thru the traps at 7200 with 28x9 slicks. It's a done deal.
Thanks for the advice.
Clark
