Old 12-07-2010, 06:48 PM   #1
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Default Leaky Jerico trans
A question Mr. Reptile may have the answer for, but how do I get this thing to stop leaking. Oil comes out around the area the arrow is pointing to. (Not sure of the correct name) This isn't a shaft that turns but turning the input will get oil leaking around the edges here. It isn't coming from the bearing cover. I've tried putting a thin skim of sealer over it but the leak persists. I'm at the point I need a drain plug in my bellhousing as it's always got gear oil inside.. Suggestions??
Dale Posnick
Dinsdale is offline   Reply With Quote
