Old 11-23-2010, 09:54 PM   #1
hemidup
Default Mopar 833 transmission ?
Anyone still running one? If so, how much hp/tq and at what race weight?
Jerry Williams
NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's.
hemidup is offline   Reply With Quote
Old 11-24-2010, 02:51 PM   #2
treessavoy
Liked 4 Times in 4 Posts
Default Re: Mopar 833 transmission ?
They ran these things in early pro-stock and in the altered wheelbase nitro funny cars in the '60's. Find an 18 spline aluminum case 833 which came behind street Hemi's as well as race Hemi cars and you can't break it but if you looking to be competitive in S or SS you need to buy a race trans from Jerico or the others for they are designed to take the punnishment. You'll have to do a lot of mod's to the 833 to get it to shift fast and engage gear changes.
JimR
Jim Rountree
Old 11-24-2010, 03:27 PM   #3
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
JimR
Jerry, Jim is correct. I should dyno the bracket motor to see what it puts out, but I am guessing 600HP maybe a bit more.....I grenaded a rather well done liberty worked 833....imput and 2nd gear doing the jerico shift method...fixable but not optimal..You could race one, but you would have to kick the clutch....I scored a jerico....More gear options, etc.
If you need more info on the venerable 833 contact the sources: Passion performance and Brewers.
Eric
Eric Merryfield 1883 STK
Old 11-24-2010, 09:10 PM   #4
hemidup
Thanks guy's. Working on a barn find 67 Belvidere. Last time it was raced was back in 72-73 and has sat all this time without turning a tire since then. The car is a jewel. 10" Firestone 500's on 6" Keystones, truck leaf springs, custom laquer paint job, fender well headers, 513's, cast iron 18 spline 833 Liberty with blue fluid, (guessing B&M atf?). He want's to put the car back on the street. Built him a mild low deck 428 hp engine, replaced the 5.13's with 3.55's, with a standard rebuilt 18 spline 833.
Anyway's, I have another customer willing to buy his old transmission and installing it in a 68 Dart. RB wedge putting out 707/686 on pump gas. Think it'll hold up or should I steer him in another direction.
Jerry Williams
Old 11-25-2010, 10:22 AM   #5
james schaechter
If this is a street strip car that a person is careful with I would think you could make anything last, but any serious effort to hook it up would be met with a high potential for Carnage.
No matter what transmission is picked, if this is to be raced, make sure that the type of clutch is considered also.
We sold one of our spare Jerico's to a old timer with a hopped up 56 Chevy. Weighs like 3700 lbs with a 355. He kept breaking T10s. Not a big surprise there with slicks on, but I only agreed to sell him the trans if he bought a nice soft clutch too.
Bottom line is that he has a combo that he will likely never break and prior to that, he was snapping parts like crazy. A little extra money up front makes for a lot more fun and saves money down the road.
James Schaechter 3163 STK
Old 11-26-2010, 06:27 PM   #6
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
I wonder if the T10 would have held up with the soft clutch? I busted my share of Super T10 stuff back in the day with the old style clutches.
www.motorsportsinnovations.com
MOTORSPORTS Innovations is offline   Reply With Quote
Old 11-27-2010, 11:55 AM   #7
Eric Merryfield
Jerry if he goes this route, I have left over parts that might come in handy....Lakewood blowshield with inspection hole(out of cert but perfect for the street) and a Mcloud Soft lok setup ready to be redone, just send it off to Hyatt, and a old school period correct vgate shifter(I think thats whats its called, nice shifter.....but no Long shifter! Call if you need/want anything/pictures
Eric
Old 11-30-2010, 05:24 AM   #8
hemidup
Eric
Thanks Eric. I'll call if needed, like I always do.
Jerry Williams
Old 11-30-2010, 11:39 AM   #9
Eric Merryfield
Smile Re: Mopar 833 transmission ?
Sure Jerry. If he does go the 833 route, mine just needs another imput shaft and 2nd gear..(not minor pieces of course)..best to have a spare handy, just in case......if/when it breaks, he could be looking at a good month or two of downtime waiting on parts, machining and labor.....Assuming you are talking about a faceplated/hardened liberty gears treatment on a 833 crash box.
Eric
