View Poll Results: Whats a Fast run under the current index? | |||
-1.0 under index |
108 | 77.14% |
-1.5 under index |
29 | 20.71% |
-2.0 under index |
2 | 1.43% |
Faster than -2.0 under |
1 | 0.71% |
Voters: 140. You may not vote on this poll |
Thread Tools | Display Modes |
Liked 584 Times in 94 Posts
With the 2009 indexes reduced by -.3, I was wondering what all the racers consider a FAST (Bad *****) run. Is it -1.0 under? 1.1under? or 1.2?under, or even faster?. Second part of the question, where do you think the NHRA AHFS trigger should be set? This is just a survey. It has nothing to do with NHRA, IHRA, or SRAC. I'd personally just like to know what all the racers out there are thinking, additionally, if you're a keyboard racer, and haven't raced in the past year...I don't care what you think.
Liked 75 Times in 29 Posts
Trigger should be at -0.85 (same as 2009).... I wouldn't be opposed to -0.80 or -0.75 either.
... and review quarterly with a rolling 6 or 12 month average .... a better way to weed out the soft combos.
Tom Sheehan SS GT/NA 1046 |
Liked 13 Times in 9 Posts
-1.00 under (-1.30 under the old index) is very fast. -1.20 under today is CRAZY fast.
$.02,
I aboutley agree.
Ed Wright 4156 SS/JA |
Liked 1,840 Times in 418 Posts
In good air, 1.0 under is pretty stout, for any class except AA/SA and AA/S. For those cars, in good air, about 0.8 under is pretty stout.
I think those should trigger a review, and 1.15 should be instant 3.25%, of course, you won't have separate numbers for the AA classes. For every 0.05 under you go past 1.15, they should add about 1%, so that 1.25 under would be 5.25%. But they all should be factored back to an SAE standard day at sea level from the actual conditions at the track when the run was made, and instant HP should only come after a complete "National Record" tear down that is mandatory.
Alan Roehrich 212A G/S |
Liked 2,354 Times in 554 Posts
Why not use the 1/8th mile times when reviewing a combination?
I'd say use 1000' numbers and compare them to known good runs to catch the sandbaggers but that would make too much sense.
Chad Rhodes 2113 I/SA |
Liked 100 Times in 45 Posts
As bad as the situation is with the new HP factors unless they're put into their own class it will never be resolved in the near future.As far as I see in the rule book there is no rule against bagging.You can't arbitrarily hand out HP based on 1K ft times.Every car is different.
This arguement is gong to be as bad as the one about the chicken and the egg.
Former NHRA #1945 Former IHRA #1945 T/SA |
It would make the racing better for sure. I watched some qualifying at Charlotte earlier this year and was shocked at how many people were "protecting" their combination.
1000' times are a pretty good indicator. 1000' to 1320' don't vary much between cars running similar times. The sand baggers use 1000' times to know what to dial and know where they stand in a heads up pairing.
