Old 10-31-2010, 10:20 PM   #21
Jack McCarthy
Liked 477 Times in 117 Posts
Default Re: Stocker pistons; If none are on the approved list, what to do?
didnt have too much trouble with the witch doctor pistons, ross made them nhra approved them in about 5 weeks... went thru bruce
jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 10-31-2010, 10:34 PM   #22
FED 387
Liked 333 Times in 180 Posts
Alan--I sent you a PM --Comp 387
Old 10-31-2010, 10:37 PM   #23
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Talking Re: Stocker pistons; If none are on the approved list, what to do?
Originally Posted by ALMACK View Post
Yeah, I just got the same answer from Greg @ JE in an e-mail.
Looks like this process will take awhile....LOL
That will give you time to get a second job to pay for them and the tricky dickie rings you'll need.
You might want to try my piston co.The Fred Flintstone Forging Co. in Bed Rock Ca.They have a direct line to Danny Gs office.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 10-31-2010, 11:06 PM   #24
Jeff Lee
Jeff Lee's Avatar
Maybe things have changed but I had great success with CP pistons turn around time, even on pistons not previously approved for Stock.
My Super Stock engine got a set of Diamond pistons in about three weeks (which do not require NHRA approval).
Along the lines of what Ed said, on some engines it can get real costly with rings if it is an odd size. My 390 AMC being one of them. I ran a 4.230" bore in Stock and I spent a lot of $$ on rings and spacers to run the 1.2mm width. It may be more cost effective to run a smaller bore if it is a more common ring size. All depends on if your after every hundredth in ET or not.
Now NHRA allows +.075 which is 4.240" for my 390. What that means to me is I can use a 4.250" ring package which will file down nicely. That gets me rings for a few hundred dollars instead of over a thousand dollars.
Jeff Lee 7494 D/S '70 AMX
Old 11-01-2010, 12:03 AM   #25
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Pardon my AMC stupidity, but a 4.23 bore is pretty big (thinking 427 Ford here) so what does that make the crank stroke to be 390 CI. No scientific information to prove it's any better but I've always liked the big bore/short stroke idea..
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 11-01-2010, 12:19 AM   #26
GTX JOHN
Liked 2,487 Times in 698 Posts
About 3.4 inches I believe.
Old 11-01-2010, 02:26 AM   #27
Jeff Lee
Jeff Lee's Avatar
AMC 390 stock bore / stroke is 4.165" / 3.574" and by the time your done boring & stroking it for NHRA competition it's around 402".
The 401 AMC is 4.165" x 3.68"
And yes, 4.230" bore is standard FE 427.
Old 11-01-2010, 02:55 AM   #28
Dinsdale
Dinsdale's Avatar
Thanks Jeff.
I am familiar with FE stuff (have a couple) but am quite surprised at the big bore/short stroke of an AMC 390. Learn something every day.
Dale Posnick
Old 11-01-2010, 07:36 AM   #29
I'm good, I don't need a set for a while.
My delays had very little to do with JE, and quite a lot to do with NHRA. See the explanation above.
Old 11-01-2010, 01:36 PM   #30
Ed Wright
Ed Wright's Avatar
So, you don't have to give them a piston?
I had to donate a Scat rod to get them approved.
Got a BowTie block PN approved last year, sure was thankful I didn't have to buy an extra block! <G>
Ed Wright 4156 SS/JA
