Old 10-01-2010, 09:08 AM   #1
LuvMopars
Default Mopar stocker question
I would like to build my 71' Duster into a D/S stock eliminator car, and I have a few questions, if anyone can help. ( I may be dreaming, but who knows...we'll see )
Who has a good clutch set-up that wont break the bank and doesnt require you to go into the can every pass ? ( as in low maintenance )
I am sure I will have more questions.
Thanks so much,
J.C.
(434) 665-9541
LuvMopars is offline   Reply With Quote
Old 10-01-2010, 11:11 AM   #2
Rod Greene
Liked 242 Times in 81 Posts
Default Re: Mopar stocker question
The best clutch guy out there is Rob Youngblood at Advanced 208-880-6214. He can get you set up.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is online now   Reply With Quote
Old 10-01-2010, 05:07 PM   #3
Jeff Lee
Jeff Lee's Avatar
If you want to race a D/S car, it will "break the bank"; bank being a relative term as I do not know what you have to spend on this project. But no matter your resources, it won't be cheap. And if you want a clutch that will break the bank in terms of added ET, lost MPH, more time under or in the can, more broken parts from the can on back and more frustration as you are continually beat, then by all means, go for the cheaper products. Using the suggestion of Rod Greene will yield the opposite of the woes I just outlined. Pricing of the single 10" Sportsman clutch assembly is competitive to the 10 1/2" Soft-Lock assembly by McLeod. And Rob offers almost total access for tuning while with McLeod and most others, you are entirely on your own.
It's the inferior products that keep you under the can all day. Been there, done that!
Jeff Lee 7494 D/S '70 AMX
